Correct way to test compression?
Old Feb 18, 2006 | 11:04 AM
tractoman's Avatar
tractoman
What is the best way to do a compression test? All plugs out? Engine warm or cold? Throttle open or closed? I want to check out the new truck I am getting, but am not sure I know the correct method.
Thanks,
Mike
Old Feb 18, 2006 | 11:11 AM
MBBFord's Avatar
MBBFord
Do you have a compression testing kit? I got one from autozone a while back, before I rebuilt my 302, and I just followed the directions, I want to say I just took out one spark plug at a time, but can't remember for the life of me right now.
Old Feb 18, 2006 | 12:03 PM
Mil1ion's Avatar
Mil1ion
Welcome to the site
This question should have been asked in the general automotive discussion forum as it isn't really 73-79 truck related.
Before it gets moved!
Plugs out ! to allow possible cylinder leak across head to other cylinder.
First DRY Test then Wet Test
only 3 complete cranks to build pressure as this will allow consistency per cylinder.
Cold is best as ALL the parts will be the same temp and will prove to give a better indication of the condition of the engine.
If the engine is heated some parts expand differently
Carb left in normal position.
Old Feb 18, 2006 | 01:03 PM
monsterbaby's Avatar
monsterbaby
Wrong, carb should be in open position, cold will give you the lower compression to tell you if the rings are still seating decently (warm test will have the pistons expanded and will raise the compression test and make it look better but cold will tell you more accuratly what the rings are doing.) don't bother with the wet test unless you have one or more cyl that are way out of line, then a wet test will tell you wether it's the rings or something top side. plugs in or out isn't really a big deal although I test with them out forst because you can get faster crank speed, and second because it takes less amperage to turn it over that way so your not running the battery down so bad and thus spinning hte engine at a slower speed on the last cyl than you were on the first cyl.
Old Feb 18, 2006 | 03:03 PM
Boltgunner's Avatar
Boltgunner
My 76 Ford Shop Manual sez plugs out, carb open, warm motor, 5 cranks, lowest pressure no less than 75% of highest reading, good battery (I put mine on a charger now and then during a compression check a couple of weeks ago), tablespoon of oil in the spark plug hole of the out of spec cylinder to check for bad rings.
Old Feb 18, 2006 | 05:21 PM
Mil1ion's Avatar
Mil1ion
Okay , how about both cold and warm ,,,if you have the time ?
Old Feb 18, 2006 | 08:06 PM
7702fordboy's Avatar
7702fordboy
sorry wrong post onthis subject
Old Feb 19, 2006 | 10:22 AM
trinogt's Avatar
trinogt
I'm with the warm test. You want to know your compression under normal operating conditions (warm).
If engine is dead, you have no choice but to test cold. (like purchasing a non-running vehicle, you want to diagnose the problem)
Throttle fully open will ensure enough air gets into the cylinder for the test.
All plugs out is best, but not practical for dual-spark plug engines. (duh! haha)
With EFI, pull fuel pump fuse.
And as mentioned, wet test only needed when a cylinder is low. Even if within 75% of other cylinders, a wet test on a 'lower' reading cylinder will help diagnose a ring or valve problem.
I like the 5 crank procedure. 3 just doesn't cut it for me. I have gotten an additional 10-20 psi on those last two cranks.
Mark
Old Feb 19, 2006 | 10:27 AM
hotroddually's Avatar
hotroddually
Thumbs up
i agree totally.this will give you the most accurrate results of what kind of shape the engine is in. you would/should be more concerned with the compression on the engine at operating temps than when its cold.-billy
Old Feb 19, 2006 | 10:31 AM
GLR's Avatar
GLR
Carb is in wide open throttle position to keep fuel from entering cylinders, dont forget to ground coil wire to dist or disconnect primary wire at coil, to keep from getting shocked.
Old Feb 19, 2006 | 11:49 AM
monsterbaby
Actually fords have this really unique deal setup so you don't have to worry about that little problem, it's called the starter soiliniod is on the fender and you can either jump it or put in a remote start button and not even have the ignition in the one position, works really good.
Old Feb 19, 2006 | 02:18 PM
Boltgunner's Avatar
Boltgunner
Got me one of those "slot car" starter buttons (finally) and you are correct, hooking up to the noid up on the fender was really cool! Doesn't take much at my age to entertain me now...
dpoc
1983 - 2012 Ranger & B-Series
20
Dec 4, 2012 11:14 PM
darkstar8
Jun 21, 2011 02:45 PM
66 POJ
Dec 29, 2006 05:21 PM
smiller4597
Nov 13, 2005 09:44 PM
lariatbob
Dec 16, 2004 06:14 AM
