When I owned my 2012 Ram 6.7 Cummins the dealer told me NOT to let it idle excessively more than 5 minutes. They said this will cause the DPF to build up soot. Should I follow the same advice for my 6.7 PSD or is it okay to idle without worry? For instance, when I'm hooking up the fifth wheel, does anyone know the official Ford answer?
you're ok.. the excessive idling is like a powerline service truck sitting for hours while the guys are up on the pole, or an ambulance sitting for hours.
but if you do this occasionally no issue.. (I idle at the mall waiting for my wife once every other month)..
if you intend to do this more frequently.. you can wire up some of the switches and pre-built wires to raise the idle a little which helps..
see the technical sticky topic at the top of the forum, and look for "SEIC High IdleInstructions"
I think it has more to do with caking/clogging the egr valve and maybe turbo vanes.....
Anyhow, acceptable idling is generally 20% of total hours. So I guess idling 20/100 hours would be just fine in fords eyes. I don't know where or if this figure is printed but I do believe it is printed somewhere in ford literature/manual/tsb/warranty guide.
I don't worry about it, I let it idle whenever the thought strikes me.
I looked in the owners manual but I couldn't find it anywhere. While I'm on that subject, I don't like the fact I have to turn to this page or that page when I'm trying to get answers to something. The manual refers you to a different page for the same subject but for multiple variances.
as the engine runs it gradually fills the diesel particulate filter. The filter cannot regenerate while the truck is idling unless you do an operator commanded regeneration - a function which is available only on the xlt trucks. Thus if you do a lot of idling and do not follow the prompts (drive to clean exhaust filter) you could be in for a trip to the dealer to have your exhaust filter cleaned. The short duration idling you describe should not be a problem. Generally though, prolonged idling for these engines is not a great thing.
It is not uncommon for me to let my truck idle for hours at a time.....No problems and my service advisor at the Ford Dealer said it is no big deal.
Here in TexUS that ac is on max air all the time when I'm hooking up, etc...
and the towels are ready to wipe off the sweat so why would I NOT let it idle with the ac on
5th ford diesel with remote start and have heard that since 2002 and still ignore it
i have 1196 engine hours and 399 idle hours. i calculated it and a little over 33% total idle. seems like a lot, i don't know. i have 30,400 miles on the truck.
