Looking a good cleaner!
Old Jan 27, 2009 | 06:55 AM
go6.0go's Avatar
go6.0go
Hi every one,
I'm the newbie and I was wondering if anyone could help me find the best cleaner to keep carbon build up off the EGR and Turbo in my 2005 Ford F250.
Preferbly a cleaner that will not require an oil change after using it.
It needs to be cleaned again and I don't have $370.00 to give my local dealer to clean it for me.
Thanks,
go6.0go
Old Jan 27, 2009 | 07:58 AM
jmaskew's Avatar
jmaskew
You can use carb cleaner for the egr valve. I'm sure the same for the turbo. Do you use fuel additive? Do you idle the truck alot? If you idle alot you should install the high idle switch. Here is a picture of my egr valve after letting it idle alot everyday for a few months (actually around 10,000 miles) using the high idle mod.
Old Jan 27, 2009 | 08:16 AM
go6.0go's Avatar
go6.0go
I have used Lucas before but not for a long time (bout a year now)
I try not to let it idle to long, just depends on how hot my turbo is.
The truck has a high idle worm up but no high idle mod.
Letting idle to run in the store, would that be considered too long?
VQT
Mar 19, 2012 10:21 PM
mblanken881
Dec 17, 2011 08:35 AM
Joeg4go
1983 - 2012 Ranger & B-Series
Jun 22, 2010 05:36 PM
adbscu
Air Intakes, Air Filters & Ram Air
Dec 20, 2009 03:26 PM
tinkybug
Sep 5, 2005 12:52 AM
