Too much idling?
Old Aug 17, 2006 | 08:05 PM
nico963's Avatar
nico963
Smile Too much idling?
Quick question for you guys,I have seen many post about not letting your 6.0 idle for long periods of time except if you have high idle and I let my truck cool down 2-3 minutes before I shut it down every time, now I know thats not very long but will it make a mess of my egr valve later down the road or any thing else?
p.s I LOVE MY 04 6.0 GREATEST TRUCK EVER MADE!
Old Aug 17, 2006 | 08:08 PM
BowTieHatr's Avatar
BowTieHatr
unless you're coming off a long hard tow, you dont need to let it idle.
Old Aug 17, 2006 | 11:32 PM
LVEILLON's Avatar
LVEILLON
If you are going to idle for a certain reason then setup the Hi-Idle mod so that the engine will perform as if it were being driven.
I'm having a RealACPower system installed in my truck this weekend and the Hi-Idle mode will work in conjuntion with the output.
Old Aug 17, 2006 | 11:39 PM
olfordsnstone's Avatar
olfordsnstone
On some models you can wire the PTO idle wires through a switch to accomplish an on demand (switched) high idle. Nice if you have to idle for extended periods in your application. If you have the upfitter switches, this is an easy set up to do. I think instructions might be found in the tech folder. If not, I'm sure KW will direct you to a link for that.
Avoid extended idling, except for cooling the turbo down after a good workout. Shutting down an engine, where the turbo has been worked and heated up, can cause coking, so this is the exception where you DO want to idle for several minutes. Other than that, if I am driving more conservatively, I will only let mine cool down for about a minute for city type driving. In road construction, where I am stuck sitting for 15 minutes at the flagman, I shut that sucker off instead of excessive idling.
Old Aug 18, 2006 | 01:22 AM
JORYLEE76's Avatar
JORYLEE76
Question about cool down... Im getting ready to go from Seattle Washington to Salt Lake City Utah. Thats about 900 miles or so of road ill be on. when i stop for gas.. are you saying that i need to let the truck cool down at an idle before i turn it off to pump the fuel??? or becuse its only a few min that ill be at the pump it will be ok to shut it down??????????? Thanks
JoryLee
Old Aug 18, 2006 | 06:38 AM
Crash687's Avatar
Crash687
If your comming off the freeway just to refuel, leave it idle.
When your running freeway speeds or towing, let it idle for a few minutes before shut down.
Old Aug 18, 2006 | 06:48 AM
JORYLEE76's Avatar
JORYLEE76
Great thanks for the heads up..
JoryLee
Old Aug 18, 2006 | 08:32 AM
kw5413's Avatar
kw5413
nico963, here's the link to the 6.0 Tech Folder:
https://www.ford-trucks.com/forums/3...ch-folder.html
Lotta info including idle mod.
Good luck
Old Aug 18, 2006 | 09:16 AM
scafes's Avatar
scafes
Correct. You don't need to perform the idle mod just to run into Kiwk Shop. Too many people think that is necessary. You are not going to wet stack from idleing for minutes at a time and if you drive any type of freeway often, you will blow it out anyway.
Now if your idleing for extended long periods and your vehicle is a city driver, then you should probably consider it.
Old Aug 18, 2006 | 06:47 PM
nico963's Avatar
nico963
Thanks guys!
Old Sep 8, 2006 | 05:28 PM
dapgar's Avatar
dapgar
when reading my 06 manual. I got the impression that after 130 seconds of idle, my truck will automatically switch to HIGH IDLE mode, has anyone seen if this is true?
i have let mine warm up for several minutes but never noticed that it started to idle faster after 130 seconds.
maybe it's an option?
I normally let my truck idle when i am just stopping for a short time or in the winter, it idles a lot, at least my 97 did, and i'm sure my new 06 will also.
Old Sep 14, 2006 | 04:56 PM
larryjj's Avatar
larryjj
I would also like to know if the diesel engine will automatically switch to high idle
Old Sep 14, 2006 | 05:39 PM
tazo's Avatar
tazo
When I hook-up the trailer in the mornings I let the truck idle and it switches to high idle mode after a few minutes. I am guessing it will prevent wet stacking. As soon as I put my foot on the brake the idle comes back to normal. I also hooked up the high idle to the upfitter switch and it works wonders on warm up. Hope this helps.
Old Sep 14, 2006 | 07:22 PM
wylecoyote's Avatar
wylecoyote
Mine will only idle up when its cold out. I dont know why, But in the summer it wont idle up. I let my truck warm up summer or winter.
Old Sep 14, 2006 | 08:22 PM
dapgar's Avatar
dapgar
the manual says it will auto high idle when it senses cold ambient temps.
so soon, i will find out on a colder morning this fall if it works. i still plan on doing the switch though.
