Ts chip with PHP tunes - problems
Old Aug 22, 2014 | 07:21 PM
BeachEx's Avatar
BeachEx
Installed my chip, think I cleaned pretty well.
In position 1 (stock) it lopes real bad and shuts off.
In HP positions, in high RPM it acts like it doesn't want to shift right, Jumping and bucking.
Maybe clean it again?
Thanks for any help,
Josh
Old Aug 22, 2014 | 08:04 PM
F350-6's Avatar
F350-6
Got pictures of the PCM where you cleaned it? Don't clean anymore until you're sure you haven't cleaned too much.
Old Aug 22, 2014 | 08:11 PM
BeachEx's Avatar
BeachEx
No pictures now, but I can get some tomorrow morning
Old Aug 23, 2014 | 09:00 AM
Tugly's Avatar
Tugly
I aggressively cleaned mine, then I re-tinned the contacts. It's a good idea to put dielectric grease on there to prevent oxidation over time.
Old Aug 23, 2014 | 10:31 AM
jeffreyt's Avatar
jeffreyt
Question: where did you get the chip? The reason I ask is that I didn't think Php offered the TS anymore since the hydra came out, although they will still flash tunes onto them iirc. Is there a chance the tunes on the chip are for a different PCM strategy than what you have? Or maybe even for modified injectors?
Old Aug 23, 2014 | 11:11 AM
BeachEx's Avatar
BeachEx
I bought the chip from KT Performance, gave them my pcm code so that shouldn't be the problem
Old Aug 23, 2014 | 11:15 AM
jeffreyt's Avatar
jeffreyt
Gotcha, I forgot Php does have third party vendors offering their tunes. Well, if the cleaning and preparing the board doesn't fix it, you may call KT and see if they can reburn the chip. I've read a single instance where the calibration file on the chip was corrupted for some reason. Extremely rare though.
Old Aug 23, 2014 | 12:45 PM
BeachEx's Avatar
BeachEx
Too much cleaning?
http://i166.photobucket.com/albums/u...psaclt8ew4.jpg
Stupid smartphone will not let me post pic tge right way!!
Old Aug 23, 2014 | 01:21 PM
jeffreyt's Avatar
jeffreyt
Here you go. Have to type the code in manually [IMG] link [/IMG ]
Old Aug 23, 2014 | 01:23 PM
jeffreyt's Avatar
jeffreyt
It's possible, I cleaned one one time where the color was showing and didn't have any problems, but I've read people that have had to re-tin the contacts. Maybe one of the other guys can tell you more.
Old Aug 23, 2014 | 01:45 PM
hydro man 17's Avatar
hydro man 17
If you can see copper you went too far for my liking. Can make for loose connections.
Old Aug 23, 2014 | 03:13 PM
jeffreyt's Avatar
jeffreyt
If you are decent with a soldering iron, you can retin the contacts. The easiest way would probably be to load up a solder wick and just paint it on with the iron keeping the wick soft. That's what "I" would do...
Robbgt
34
Aug 10, 2021 04:34 PM
f1501987
Dec 3, 2011 02:55 PM
brooksbronco17
Mar 3, 2010 08:48 PM
Robbgt
52
Mar 25, 2008 03:44 PM
avi
Aug 4, 2007 07:46 AM
