another lift question
Old Aug 17, 2014 | 12:15 AM
RRTREE's Avatar
RRTREE
I've got a 2004 limited 6.0 with a 6" BDS lift and 37's. Kit has been on about 4 months and now is rubbing a lot when wheels are turned and going over bumps. I figure that the new springs have settled. I know I probably should have stuck with 35's but 37's look better. Anyway I need 2 more inches and don't want to buy a whole new lift. Has anybody tried putting 2" mini packs along with a 6" kit?
Old Aug 17, 2014 | 12:42 AM
EXv10's Avatar
EXv10
Too dangerous in the front with the lift is my assumption. I would try 1" shackles.
Old Aug 17, 2014 | 08:05 AM
jayjjcc's Avatar
jayjjcc
What's the rear look like? Throw on 2" shackles and a 4" block?
Old Aug 17, 2014 | 08:13 AM
hav24wheel's Avatar
hav24wheel
Where are the tires rubbing? A lot of times a little trim will clear things up easily.
Old Aug 17, 2014 | 09:51 AM
RRTREE's Avatar
RRTREE
http://cimg3.ibsrv.net/gimg/www.ford...34e1de4c64.jpg
Rubs on front bumper and inside wheel well. Don't really want to start hacking at my fenders if possible. Dose anybody make flares that give you more room?
Old Aug 17, 2014 | 10:21 AM
EXv10's Avatar
EXv10
1" shackles are not invasive and would probably be just enough plus now you know where you could do a tiny bit of hacking if necessary.
Old Aug 17, 2014 | 04:42 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Show us a picture of your front leafs
I'm with Brent on this. A 1-2" lift shackle is dead easy to install. Then slap another leaf in the back and you should have plenty of hieght
Old Aug 22, 2014 | 10:29 AM
wrxin's Avatar
wrxin
Hubcentric wheel spacers fixed my rubbing on the leaf springs and some cutting on the plastic under the front bumper fixed the rest of the rubbing.
Old Sep 1, 2014 | 10:04 AM
Krueger1's Avatar
Krueger1
Hey RRTREE, nice lookin truck! I'm going to put the same lift on my X in the spring, have a couple questions. Did you have to replace your swaybar end links in the front, and were there any other parts you had to replace? It's my daily driver so I can't leave it sit while I wait for parts, tryin to make sure I have everything covered. Thanks brother!
Old Sep 1, 2014 | 01:49 PM
Nolo263's Avatar
Nolo263
I have read on here where people move the whole bumper forward an inch that might help
Haulinbass02
Dec 5, 2017 04:08 PM
joeyd61
13
Feb 16, 2009 09:57 PM
1st_FordTruck
2004 - 2008 F150
Jul 13, 2006 09:59 AM
muffdr
Jan 11, 2005 08:53 AM
stealth1
Jul 5, 2004 05:20 AM
