Sponsored by: Real Truck
Burning Fog Lights
Old Aug 13, 2014 | 08:04 PM
musclecars90's Avatar
musclecars90
Burning Fog Lights
So I've looked and looked to try to find help on this and no one had my problem. Last week I noticed my fogs stopped working. So I figured there may be a chance that they were burnt out. Hooked them straight to a battery and they work. Next I checked power at the plugs and no power. Checked the fuse and blown. The only fuse I had on me was a 25 amp fuse. Big mistake. Smoke started coming from the fuse box (palm to the forehead). Well it didn't blow the fuse but still nothing. I got power at the headlight switch and started tracing wires. From what I had read there is relay but it is inside the fuse box? Is this correct. I'm trying to pin point where the problem lies. There aren't any burnt up wires behind the fuse box and now I'm at a loss.
Old Aug 13, 2014 | 08:29 PM
Yahiko's Avatar
Yahiko
Well if it's the 04 in you profile I have a diagram I can post.
I just need to get the BJB diagram for you.
Sean
Old Aug 13, 2014 | 08:48 PM
musclecars90
Sorry I have not updated my profile yet. The 04 got wrecked in February by a drunk driver hitting me head on at 95 mph. The truck now is an 06.
Old Aug 13, 2014 | 09:07 PM
Yahiko's Avatar
Yahiko
I take it you did OK in that?
I will get the 2006 info and load it.
But it looks like the Fog Lamp Relay is buried in the CJB
C270h is the connector that you need for the Fog Lights.
I put a few PDFs in for you to look at.
Sean
Old Aug 13, 2014 | 09:17 PM
musclecars90
Thanks. I will take a look at them. And yea I am ok now. I was banged up a bit for a while.
Old Aug 13, 2014 | 10:01 PM
Yahiko's Avatar
Yahiko
Sorry to hear that some fool did not know
to call a taxi. But it's good you OK now.
Let me know if your need more diagrams.
Sean
Old Aug 14, 2014 | 05:44 PM
musclecars90
So I'm pretty sure its the relay and something else. Hooked a volt meter to the tan/orange wire and turned on the fog lights with key on and not getting power. So I decided to hook a hot wire to pin 2 to see if I get power at the pig tails and nothing. So I decided to ohm out the wire to see if I had a break somewhere. Ohm'ed out good. Is there another junction between the CJB and the fogs?
Old Aug 14, 2014 | 08:47 PM
Yahiko's Avatar
Yahiko
Did you check the ground from the plug C152 & C162 for the fog lamps?
You also have C1045. You will find this connector under the headlight
on the frame head or there about. It's the feed to the Fog Lamp harness.
S100 & S101 for the ground side
G100 for the main ground point.
Instead of a volt meter use a test lamp.
You can have 12 and almost no current flow.
The test lamp will show that with a very dim
light or no light at all. You can also use it to
check a ground by placing the clip on a + terminal
of the battery. Touch it to the ground point in the
connector and it should light. Compare that to when
you touch it to the frame and the lamp should be near
to the same brightness.
Sean
DeathValley1981
2009 - 2014 F150
19
Nov 21, 2016 11:27 AM
powerstroker02
Electrical Systems/Wiring
Oct 22, 2009 12:21 AM
texastech_diesel
Feb 4, 2008 05:37 PM
Quackhead94ranger
Jan 27, 2005 07:11 PM
smitty240
Jun 30, 2004 09:18 AM
