Hot no start
Old Aug 13, 2014 | 05:24 PM
cope1972's Avatar
cope1972
Hot no start
I have hot no start. New hpop, ipr, d-plugs, stand pipes and icp. I did an air test cold. No leaks so thinking since it's a hot no start I need to get it hot and test it. Question is if I hook up my test line to my ipr instead of hooking up the regular harness for ipr will my truck start? Cause I'm using 12 volts to ipr to close it to do air test. I don't know how to get test line hooked up when it's hot without burning myself trying to hook it up. So can I hook my test line and start truck run it to get it hot then do air test?
Old Aug 13, 2014 | 10:37 PM
bismic's Avatar
bismic
It doesn't have to be hot to do the air test. You need to blow the oil out of the system first, then listen for leaks.
F0rdF0rever
Feb 8, 2019 03:13 PM
cookingguy
Oct 16, 2014 08:18 PM
cope1972
Oct 7, 2014 04:12 PM
cope1972
Sep 22, 2014 06:51 AM
ROBBINthaHOOD
Nov 4, 2013 12:44 PM
