1978 Paint code S - best supplier?
Old Aug 10, 2014 | 11:26 AM
hhight's Avatar
hhight
The title says it all. I need some Bright Dark Blue Metallic. I don't really want to have to pay $35 + s/h for one spray can. I have a spray gun and air compressor. Where did you get your paint?
Old Aug 10, 2014 | 11:37 AM
HIO Silver's Avatar
HIO Silver
Not enough info.... Which system? Single-stage urethane? BC/CC?
Look up and contact your local jobber.
Old Aug 10, 2014 | 11:43 AM
fmc400's Avatar
fmc400
MSEE
Is there literally a paint code called "bright dark?"
Old Aug 10, 2014 | 11:52 AM
HIO Silver's Avatar
HIO Silver
Nope... it's Midnight Blue Metallic.
Old Aug 10, 2014 | 12:22 PM
hhight's Avatar
hhight
I'm seeing Bright Dark Blue everywhere, though. Now I'm confused.
1973-1979 Ford Truck VIN Tag Codes (Exterior Paint) - FORDification.net
A couple of rattle cans will do, just trying to avoid spending a c note to paint a dash.
Old Aug 10, 2014 | 02:11 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yes, the Ford parts catalog lists paint code "S" as "Bright Dark Blue Metallic".
Old Aug 10, 2014 | 04:08 PM
Blue and White's Avatar
Blue and White
I've worked with TCP Global/Auto Color Library for larger orders. The smallest they offer is 1 qt so it may not be a good deal. Your automotive paint distributor may be better for a pint.
In general, single stage mettalics are very hard to spray. Lacquer is not to bad but enamel is very difficult. For the interior, single lacquer would probably be my choice though base/clear with a SG clear could be nice.
Color Chip Selection
Old Aug 10, 2014 | 04:12 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I was going to suggest them too, I've used them several times with good results but I checked, a quart of enamel single stage is $55.00 plus shipping.
Old Aug 10, 2014 | 05:00 PM
fmc400's Avatar
fmc400
MSEE
So what does "bright dark" paint look like? Do they cancel out and just turn into regular paint?
Old Aug 10, 2014 | 08:08 PM
earthquake68's Avatar
earthquake68
It's all personal preference. I like to use PPG BC/CC Urethane. For cheap, you can go to O'Reily and Nason full base/clear. I use that on accident repair jobs. It comes out pretty well, but you have to work with it a little more to get a good finish out of it.
Old Aug 11, 2014 | 07:27 AM
hhight's Avatar
hhight
I called O'Reilly, they said they can't get my color. Maybe Ford used the same paint on a later year model that O'Reilly would be able to look up?
I appreciate all the info, folks. The PO sprayed the truck flat black, but interior is original blue, and it looks like alligator skin on the bed now. Rust is showing through. I'm following the Rustoleum thread, very interesting. And cheap! The metal flake in mine will make it difficult, but if I need to I can take it down to metal (probably should've said "Bondo" there) and my bass player has a body shop with a booth, I could pay him to spray it.
I'm not doing a restoration (yet), just want to protect the metal, experiment and learn, so I thought I'd paint the dash while it's out just to see what I can/can't do. BC/CC, poly I suppose. If it comes out imperfect, it's no worse than it is now, you know? It's not a show truck unless the show is for how not to cover rust, and how much grease/oil/misc. the underside of a truck can hold before sagging the springs! This thing is a rolling hack job, but the plus side is that I'm learning an awful lot as every piece on which I've laid a hand either needs repairing or replacing!
Old Aug 11, 2014 | 09:29 AM
RQCAPT154's Avatar
RQCAPT154
My 78 is painted bright dark blue metallic. The previous owner gave me a quart of paint that was left over and it had 81' Ford marked on the label.
Old Aug 11, 2014 | 09:40 AM
earthquake68
Another thing to try is have O'Reily scan the dash. They have this device that can scan the color and come up with a mix formula. I bet they CAN get the paint, even though they don't have a specific listing for it.
Old Aug 11, 2014 | 01:02 PM
61steven's Avatar
61steven
That options list had a 4 speed overdrive listed. Option 6 in the picture.
What Trans was a manual OD for dentside trucks? I'd love OD without the fabrication required from a ZF swap!
Old Aug 11, 2014 | 01:43 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Ford lists the ratios as 3.29, 1.84, 1.00, & 0.69.
<table border="1" cellpadding="7" cellspacing="0" width="98%"><tbody><tr><td width="20%">F-100/F-150</td> <td width="10%">1978-1984</td> <td width="10%">T170F (Code-RUG)</td> <td width="60%">Side mounted Overdrive (SMOD). Synchronized in all forward gears, with top loaded cast iron case. Used in 1978-84 Ford light duty pickups and vans. Similar in appearance to the Ford top loader transmission but has overdrive 4th gear. Three shift rails mounted to the left side of case. This unit was produced for cars also but with lighter duty bearings and gear train. Produced in 2 and 4 wheel drive versions.</td></tr></tbody></table>
traveller1002000
2009 - 2014 F150
Jun 17, 2017 12:32 PM
ndazley
23
Nov 2, 2014 07:20 AM
Knight70F250
Apr 14, 2005 08:58 PM
wresleu
1983 - 2012 Ranger & B-Series
Sep 23, 2004 01:06 AM
muscletruck7379
General Automotive Discussion
Sep 8, 2004 02:52 PM
