Sponsored by: Real Truck
ABS Question
Old Aug 5, 2014 | 07:21 PM
02 Super Duty Guy's Avatar
02 Super Duty Guy
ABS Question
my ABS light is has been on for a while now, but im finally replacing all the rotors, so its all apart now, and I would like to fix it while its still apart. my question is, is there a way to diagnose what part of the ABS is actually causing the light? at a glance, the wheel sensors and the wires going to them look sound. a few years ago, my father said he might have damaged the drivers side one, but ive inspected it in the past and didn't see any damage. I thought I saw a harbor freight ABS diagnostic tool, but don't know if itll work, and don't want to spend the money on a tool ill prolly never use again
Old Aug 5, 2014 | 07:27 PM
Modularation's Avatar
Modularation
You will not see the internal break in the wire. Code reader may narrow down which wheel speed sensor.
Old Aug 5, 2014 | 07:45 PM
dkf's Avatar
dkf
I had a bad ABS sensor on mine that got damaged when I removed it to grease the unit bearings. My truck would pull to the left and you could hear the ABS cycling. My right front sensor was bad. The ABS light came on a couple times but went off when the truck was shut off.
I would find a local garage and have them scan it for DTCs. The dealer will charge more to check the codes usually.
Old Aug 5, 2014 | 09:58 PM
02 Super Duty Guy
sorry brain fart moment..DTC?
Old Aug 5, 2014 | 09:59 PM
02 Super Duty Guy
like just a reg. scanner like autozone does? because last time they scanned it my truck threw about 11 codes lol that was like two weeks ago..i have them all written down
Old Aug 7, 2014 | 04:23 AM
Modularation
List the codes?
Old Aug 7, 2014 | 06:35 AM
Tom's Avatar
Tom
The Autozone scanner isn't likely to get those codes, if it's not on your list you will need to find someone with a more capable scan tool. Where are you located?
Old Aug 7, 2014 | 10:23 AM
02 Super Duty Guy
im in east haven,ct ...when I go out to the truck, ill grab the paper with all the codes
Old Aug 7, 2014 | 10:55 AM
Tom's Avatar
Tom
If you're ever in the Hartford area let me know. I work in Manchester and would be happy to scan your truck.
Old Aug 7, 2014 | 02:45 PM
02 Super Duty Guy
ok great thank you..ill be at the Comcast theater on weds. the 13th, but I don't think ill have the truck
Old Aug 7, 2014 | 06:29 PM
dkf's Avatar
dkf
DTC = Diagnostic Trouble Code
Blue7.3
Australia Chapter
Feb 11, 2015 01:45 AM
edsheridan
Aug 25, 2014 02:39 PM
dogg16
Jun 25, 2010 06:33 AM
DieselJr
Oct 17, 2008 09:35 AM
nobodyspecial
16
Feb 12, 2007 08:24 PM
