DP Tuner, no digits
Old Aug 4, 2014 | 10:31 PM
damons's Avatar
damons
DP Tuner, no digits
Hey, need some help, haven't used truck in a week or so, went out tonight to start it up and noticed I had no green numbers on the tuner, so I have no idea if i'm on 1 2 or 3, and truck wont start, any ideas?
Old Aug 4, 2014 | 10:43 PM
jasonc76's Avatar
jasonc76
I would check the connection on the tuner and then the chip and if no go i'd call/email dp
edit: From their support article
Turn on ignition of truck and while you are turning on the ignition to the “run” position, watch the chip switch display. Does a small dot appear in the lower corner of the switch as soon as you turn on the ignition and then go away immediately OR does no dot come up momentarily and the chip switch does not light up at all with the key on?
If a dot appears in the lower corner when you turn on the ignition then the truck is in NO START or position 0 and this is why it will not start. With the ignition turned on, press and hold the left button (-) for 3 seconds and let off and switch should reset to number 1 and truck will start.
If not dot appears in the lower corner of the switch when you turn on the ignition and the display does not light up at all then there is no power to the switch, which means the PCM is dead or the install was done incorrectly.
Old Aug 5, 2014 | 07:55 AM
damons's Avatar
damons
Thanks Jason, I have checked the connection on switch, it's good, I also do NOT see a DOT. It seems strange that the truck was fine a week ago when I last started it.
Old Aug 5, 2014 | 09:30 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
When you turn your key do you see the WTS light?
Old Aug 5, 2014 | 02:42 PM
damons's Avatar
damons
Yes, thank God it seems my PCM is ok.........
Old Aug 5, 2014 | 02:55 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
How to get out of Position 0
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Aug 5, 2014 | 03:28 PM
damons's Avatar
damons
Thanks Jody, I sent you an email. No DOT present. Not sure next step.
Old Aug 5, 2014 | 08:04 PM
damons's Avatar
damons
Pulled PCM, removed tuner, truck fired right up!
Old Aug 5, 2014 | 10:11 PM
ebbnflow's Avatar
ebbnflow
I'd do a continuity test on the cable from the chip to the switch. If I pull the switch off my F5, my truck will not start. Sounds to me like an open circuit on one of the wires to the switch.
Old Aug 6, 2014 | 12:16 PM
damons's Avatar
damons
If you pull the tuner completely out, off PCM your truck should start, it puts it back in stock mode.
imper
Computer Chips & Tuners
Aug 18, 2014 07:00 PM
alchemist1
Mar 20, 2014 10:08 AM
01PS
Aug 5, 2013 01:40 PM
will2045
Sep 19, 2011 03:26 PM
rickj000
Aug 7, 2004 05:50 PM
