how to install a push button start
Old Sep 19, 2011 | 11:04 AM
will2045's Avatar
will2045
can anyone walk me through this? the ignition is messed up on my 1979 f 150 and i need to install a bush button start any help is greatly appreciated!
Old Sep 19, 2011 | 11:27 AM
kevin316's Avatar
kevin316
or you could get a used ignition switch from a Pick n Pull.
Old Sep 19, 2011 | 11:59 AM
HIO Silver's Avatar
HIO Silver
With or without a key? Review the wiring diagrams available in the stickys for this forum.
With a key - intercept the "Start" signal from the ignition switch and install an inline momentary switch.
Without a key - Much more involved. Basically, attach all the systems stemming to and from the ignition switch for Run to one on/off switch and then a separate momentary switch for the Start signal.
Old Sep 19, 2011 | 01:32 PM
ford_pickup's Avatar
ford_pickup
Autozone sells your ignition switch and tumbler seperatly and cheap, I bought a switch, and tumbler with keys for under 20 dollars and it look right (meaning it looks original)
Old Sep 19, 2011 | 01:41 PM
will2045's Avatar
will2045
didnt realize they were that cheap. thanks ill try and get a hold of one. of hand im curious though how hard this is. cause i had already picked up a momentary relay and wiring
Old Sep 19, 2011 | 01:43 PM
ford_pickup
ITS VERY VERY EASY, JUST UNSCREW THE CAP. UNPLUG WIRING FROM OLD SWITCH AND ONTO NEW SWITCH, SCREW CAP COVER BACK ON.
Old Sep 19, 2011 | 01:46 PM
will2045's Avatar
will2045
is this what you're talking about?Standard Motor Products US23L - Standard Motor Ignition Lock Cylinders - Overview - SummitRacing.com
Old Sep 19, 2011 | 01:50 PM
ford_pickup
Old Sep 19, 2011 | 01:51 PM
ford_pickup
sorry there were no prices on that, the switch is 9.99 and the tumbler is 5.99
Old Sep 19, 2011 | 03:26 PM
MiddleNameMUD's Avatar
MiddleNameMUD
Is your wiring intact? Or is it just the switch?
msfprobass
1978 - 1996 Big Bronco
Jul 19, 2014 10:45 AM
rob8210
Apr 1, 2013 05:40 PM
brknight
Jan 2, 2011 09:13 PM
Bronco-Red
Jun 10, 2004 10:46 AM
mep123
Electrical Systems/Wiring
Oct 23, 2003 07:31 PM
