Front coil Dever install issue (Help)
Old Aug 2, 2014 | 02:56 PM
PancakeF150's Avatar
PancakeF150
I'm installing a 4 inch lift(by myself ARRRG!). My drivers side spring has a little bend in it after I trap it in the upper and lower holder and I don't know why. My passenger side is straight EDIT: Straighter. Should I loosen that spring holders and twist it around? I'm sure the spring is straight, it was when I started and my boney *** can't bend one of those suckers.
What have I done wrong? Will the spring sit normal under a load or will it still have the bow in it?
I hope the picture is revealing.
And I can't for the life of me, get the picture to post horizontal. Sorry..
Old Aug 2, 2014 | 03:27 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Ok I'll guess...yes rotate it a bit, is it seated in the cups?
Were they straight edge straight to start with?
Maybe after a load is put on it, it will straighten out?
Old Aug 2, 2014 | 03:43 PM
PancakeF150
It was straight when I began the job and I haven't done anything to bend them. I can bend things I work on but not these beefy springs. lol
I know it's seated in the top cuz it's easy to see and the bottom "looks" seated.
I am not close to where I can put a load it because I have a more work to do on it but I will admit I'm afraid of loading it with the bend in it..
Old Aug 2, 2014 | 03:56 PM
77&79F250's Avatar
77&79F250
It should settle and be ok, I would not think it would put a bend in that diameter of material.
cjbronco
Aug 14, 2018 11:40 AM
alex5550
Jul 16, 2017 01:49 PM
Tyler S
43
Feb 25, 2014 03:05 PM
MMarty
Jun 16, 2006 06:52 PM
natewoz
Offroad & 4x4
Nov 14, 2003 04:50 PM
