little extra rev
Old Jul 28, 2014 | 07:05 PM
76ClydeF100's Avatar
76ClydeF100
little extra rev
Just a curious question...sometimes when i shut of my 360 it kind of goes through a couple cycles and then stops. What is that and should i be worried?
Old Jul 28, 2014 | 07:17 PM
HIO Silver's Avatar
HIO Silver
Check your timing and AF mixture. It could be that you're running a tad rich and/or timing is off thus experiencing "run-on" with whatever mixture remains in the cylinder(s) or intake.
Old Jul 28, 2014 | 11:06 PM
OldMetal's Avatar
OldMetal
Your engine idle could be a little too fast also
Old Jul 29, 2014 | 12:32 AM
Tedster9's Avatar
Tedster9
Ah, the 70s! Wasn't that normal (almost) back then? Sometimes engines would "run on" for quite a while, maybe ten seconds. Form of dieseling iirc. That, and stinky catalytic... rotten eggs. And Disco.
Old Jul 29, 2014 | 05:50 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
One more cause could be carbon buildup. The carbon is still burning, igniting the fuel mix even when power is removed. Water drizzled down carb while keeping it running will remove it or slowly pouring Seafoam into carb.
Old Jul 29, 2014 | 01:51 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
Check for vacuum leaks also.
Sam
Old Jul 30, 2014 | 10:52 PM
76ClydeF100
Will do the seafoam tomorrow...with the vacuum leaks could that explain some of the super low idle I am experiencing when I am braking hard?
Old Jul 30, 2014 | 10:56 PM
HIO Silver's Avatar
HIO Silver
That and the carb's float setting... the carb is shutting fuel down hard and not allowing a smooth transition to the idle circuit.
I foresee carburetor adjustments in your future....there is no magic elixir with regards of a properly adjusted carb.
Old Jul 30, 2014 | 10:58 PM
76ClydeF100
I figured thats what it was...I went about 3000 miles without the carb acting up on me so I consider that a win on my part...will get it back to normal tomorrow...have you put new vacuum lines on before and felt a big difference in the motor or is that just all a mental thing?
Old Jul 30, 2014 | 11:12 PM
HIO Silver's Avatar
HIO Silver
3K miles is a long time with no carb adjustments. That's the thing with these old rigs.. they require periodic tinkering.
Replacing all vacuum lines is a good practice. If one goes bad, then the others are likely of the same vintage. I had a co-worker who replaced the radiator every two years. Period. No ifs, ands, or buts. A small crack in a vacuum hose can be tough to trace.. it can be obscured by other components or on the inside curve...all it takes is a pinhole and everything can go awry.
Old Jul 31, 2014 | 09:05 AM
fmc400's Avatar
fmc400
MSEE
Was this an EGR motor that someone decided to "get rid of all them that there smog junk?" Classic tale.
Old Jul 31, 2014 | 09:16 AM
Boodrow379's Avatar
Boodrow379
Vaccum leak
Old Jul 31, 2014 | 09:38 AM
76ClydeF100
No its a newly rebuilt 360...built to original specs
Old Jul 31, 2014 | 11:38 AM
fmc400's Avatar
fmc400
MSEE
That doesn't answer my question. If the motor originally came with EGR, and the distributor is curved and carburetor jetted for an EGR motor and you're absent the EGR system, you will see these exact same symptoms - all from heightened combustion chamber temperatures. Check the simple stuff first.
Old Jul 31, 2014 | 12:20 PM
76ClydeF100
Yeah that doesnt answer your question does it...sorry just woke up when I replied wasnt fully firing on all 8...the mechanic that did the rebuild did do a lot of stuff without me knowing and told me to trust him...last time I ever do that without being educated...this is the setup that I have...Im still a little fuzzy on the EGR system so I dont want to say something that is wrong...better to have you look at it
