heater resistor
Old Aug 2, 2014 | 06:03 AM
roadrash63's Avatar
roadrash63
heater resistor
Hey
I went to Autozone and bought a heater resistor.
I open the box and it was a Motorcraft part inside!
My question is where is the wiring harness plug that provides the ground?
I have unable to find it.
Can I just run a separate ground wire?
Thank you
Old Aug 2, 2014 | 07:44 AM
CountryBumkin's Avatar
CountryBumkin
I don't know that the terminal in your picture is a ground. On my truck that terminal goes into the small wiring harness that leads to the low pressure switch on the A/C drier (it may be just sharing the harness or it could be related to A/C operation). Perhaps the terminal is unused if you don't have A/C.
I'll take a look in my wiring diagram (as soon as I get a chance) or maybe someone else will post back with more info.
Old Aug 2, 2014 | 08:00 AM
Rogue_Wulff's Avatar
Rogue_Wulff
It does not surprise me that you found a motorcraft part, in a duralast box. I've opened many duralast boxes, and found good brand name parts, up to and including motorcraft & mopar.
I needed a pigtail for a late model dodge. Autozone or the dealer were the only 2 options, and AZ was cheaper & had one in town. Opened the box (Duralast), and inside was a Mopar labeled bag, with a factory/dealer part inside.
Yes, AZ gets a bad rap for having some cheap parts, but they do have a lot more stuff available than most of the other chains. Some of this stuff they buy in bulk from the OEM suppliers.
Old Aug 2, 2014 | 08:16 AM
Franklin2's Avatar
Franklin2
I looked at the diagrams. Without A/C you only need the 3 wires. With A/C you use 4 wires and use the other terminal.
Old Aug 2, 2014 | 09:01 AM
roadrash63's Avatar
roadrash63
Ok
thank you guys no a/c...base model .
Old Aug 2, 2014 | 09:18 AM
Rogue_Wulff
Sounds about right. Heater only = 3 speed blower with an "off" setting at the switch.
A/C = 4 speed blower, with no "off" setting on the blower switch. For all I know, the switch itself could be the same, just wired a bit different.......
Old Aug 2, 2014 | 02:08 PM
Franklin2's Avatar
Franklin2
That's what I was thinking looking at the diagrams, the fan never is truely off so the evaporator coil won't freeze up in defrost or A/C modes.
roy123
Dec 30, 2011 08:17 PM
81Ford_Stepside
Oct 16, 2008 10:27 PM
Jodell
May 5, 2008 04:53 PM
fords_forlife
Jul 1, 2006 10:40 PM
warren54
Mar 5, 2005 06:18 PM
