A/c Wiring
Old Oct 13, 2008 | 01:24 PM
81Ford_Stepside's Avatar
81Ford_Stepside
A/c Wiring
DOES ANY ONE HAVE A PICTURE OF THE WIRING FOR THE A/C UNIT FOR 80-85' .... HAD A GUY DO SOME TRANY WORK AND HE PULLED THE MOTOR TO GET TO IT. LONG STORY SHORT.. HE RIPPED OUT MY A/C WIRING AND TOSSED IT ( DON'T SAY IT..) THINKING IT DIDN'T WORK. ( WELL HE'S RIGHT,..NOW ) WELL I NEED FROM THE CONDENCER TO THE COMPRESSOR AND WHERE EVER IT USED TO START FROM?...<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/Epn9i0u20ysz_skihL1QCg"><img src="http://lh6.ggpht.com/Snn1108/SPORnfVBOYI/AAAAAAAAAlg/-dVtit2e9E0/s800/100_0744B.JPG" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/Snn1108/302cid">302cid</a></td></tr></table>
SHOULD SAY (EVERY) TRACE OF THIS IS GONE. SORRY
Old Oct 15, 2008 | 09:47 PM
ctubutis's Avatar
ctubutis
OK, I have such a wiring harness in a box in my garage, I was hoping to install it (during
what is now referred to as "last summer") but didn't get to it. Regardless, your wiring looks
like this:
There's a black wire (A) that goes to the AC compressor. The other end goes to a gray,
2-wire connector (B) but I have no idea where that connector connects. IOW I don't know
where the other mate to that connector is, I figured it'd become obvious when I actually go
install this thing (I don't have AC in my truck so that wiring is unneeded by me).
Also coming out of (B) is a green wire which leads to a small harness that runs through
the firewall beneath the heater core & fan box. Coming out of that same small harness is
(C), a single wire that plugs into the resistor mounted in the above-mentioned box.
Hope this helps!
-chris
colorado, usa
Old Oct 15, 2008 | 09:54 PM
1986FordF150I300's Avatar
1986FordF150I300
Your part b* should hook into something called a Pressure Switch by the looks of it. which is attatched to the accumaltor , it only allows the compressor to run if there is pressure with in the system.
Old Oct 15, 2008 | 10:04 PM
Franklin2's Avatar
Franklin2
Look at the connector that plugs into the compressor clutch. I believe it should have a diode wired across it to clamp the kickback voltage from the clutch windings.
Old Oct 16, 2008 | 11:59 AM
81Ford_Stepside
Would (NumberJunkie) have a part number for this?
I need from the green plug on to the compressor.
Old Oct 16, 2008 | 10:27 PM
ctubutis's Avatar
ctubutis
Sam, see if you got e-mail from me; if not, write me at
ctubutis -at- yahoo -dot- com. You're apparently set up
to not allow forum members to send you e-mail messages
via the FTE site.
-chris
