I have a F250 which decided to fry the heater blower resistor so ordered a new one now got an even bigger problem all i have got 4 coloured wires and a new reisitor block but no idea what colour wire goes to what pin can any one help, by the way this is Adele not Warren a he is to ill to do a lot so that is why i need one of you kind people to help me.
Welcome to FTE! Be sure to check out the Guidelines when you get a chance.
So are you saying you got a new resistor pack and wiring harness but the wires are different? That's easy, just compare the old one to the new one and cut the wires and hook it up. Do you know what I mean? Good luck!
Try autozone.com-they have pictures ,and a repair section.Please when posting,always try to give as much information as possible,ie,engine,vehicle year,transmission,and any thing else that may be pertinent.
Our best to you and Warren.
Adele:
After some thought ,there should be a molded plug that would mate with the resistor.You wouldn't/shouldn't have separate wires.If for some reason the molded plug is missing let us know and I/WE will try to help you.
Post back.
