Choke issues and under load bogging
Old Aug 1, 2014 | 02:02 PM
  #31
David7.3's Avatar
David7.3
I didn't notice a choke pulloff in those pictures, its a small vacuum diaphram that open the choke plate a little on startup or else you will flood the engine, you could have a float set to high, not letting in enough fuel, bad accelerator pump etc, I got into this buisness when all the is was carbs,
Old Aug 1, 2014 | 02:05 PM
  #32
fmc400's Avatar
fmc400
MSEE
No, he has a pulloff. 2100's have them mounted on the air horn.
Old Aug 2, 2014 | 03:27 PM
  #33
jomoflymo's Avatar
jomoflymo
ok so I am really hoping this works. I shot a video today of the issues. I removed the choke housing and there was a spring in there but as you know I have no hot air pipe going to it so the choke was doing nothing. If you watch the video you will see that I have no valve from manifold to attach hot air pipe to which is why I am going to a manual choke. You will also see a demonstration of the issue I am having which is the truck bogging down and stalling under partial throttle. Please watch and advise. I think maybe some tuning on the carb could get rid of this issue. I did remove the top of the carb and confirmed that the jets are not clogged.
https://www.youtube.com/watch?v=u3m_...ature=youtu.be
Thanks everyone especially redroad and FMC400. WIth your help I know I can get this old girl running
Tartersauce53
20
Dec 14, 2016 07:51 AM
Tparkin99
16
Mar 27, 2016 10:23 AM
oblivionnewtonjohn
Feb 6, 2015 07:07 AM
bradford237
Jan 14, 2013 08:24 PM
82'Stepside
24
Jan 6, 2009 12:33 AM
