Towing -newbie
Old 07-27-2014, 01:58 PM
cstanford03's Avatar
cstanford03
cstanford03 is offline
Towing -newbie
im new to the diesel thing and i recently bought a 2002 single cab 4x4 and a camper i was towing the camper yesterday back from Oklahoma and it was having a hard time towing it up hills it higher rpm is would kinda "stutter" i guess you can say but runs good at lower RPM after being at higher RPM's the temp would rise and and the engine light would come on so id slow down until it was normal which was around 55mph i noticed this morning when i was checking out everything im not sure if its the transmission cooler or the AC condenser heres a pic can someone tell me which it is so i can replace it.. im pretty sure its the problem
Old 07-27-2014, 02:16 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
That's the A/C condenser. You should pull the codes if you were getting an SES light. Trouble with a shudder under heavy throttle and load can be a sign of low fuel pressure. Did it seem to lose some power at the same time?
Old 07-27-2014, 02:42 PM
cstanford03
yes it did... but i couldnt tell if it was just because it was getting hot. I'm changing the fuel filter tomorrow
Old 07-27-2014, 02:50 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
It probably wouldn't hurt to check fuel pressure. That's actually a very good gauge to have installed permanently . . .
Old 07-27-2014, 02:58 PM
cstanford03
sounds good ill get on that too.... i think i have one laying around that i never put in the mustang
Old 07-27-2014, 03:18 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
You should have 50-60 or so at idle and be able to maintain 40+ psi under load at WOT.
Old 07-27-2014, 04:03 PM
cstanford03
ok i dont have one ill have to order one all i have at the house is an oil pressure and temp gauge
Old 07-27-2014, 04:34 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
An oil pressure gauge should be fine to test with. Just need a #4 ORB adapter if you use one of the test ports on the filter housing. There is also a square-headed plug in the 1/8" NPT fuel pressure test ports on each head; the front of the right one, near the A/C compressor, and the back of the left one, kind of under the turbo compressor housing.
Old 07-27-2014, 06:58 PM
BWST's Avatar
BWST
BWST is online now
Got Data?
what's in that condensor? Can't be ice, can it? Normally its the evaporator that ices up if air flow is low and humidity high. Looks like sand or something. Can it be washed out so you get the airflow back?
Old 07-27-2014, 07:04 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
Looks like the fins are bent over and road-sandblasted . . .
Old 07-27-2014, 07:05 PM
Tugly's Avatar
Tugly
Tugly is offline
All the fins are bent, like it was pressure-washed from the side.
Old 07-27-2014, 07:07 PM
cstanford03
Yes all the fins are bent over I think it's beyond repair I'm looking to replace it and I think that's what is restricting air flow to my radiator
Old 07-27-2014, 08:05 PM
binuya's Avatar
binuya
binuya is offline
Get yourself one of these radiator comb/fin straighteners. They work great:
http://www.google.com/url?sa=i&rct=j...06596163427028
Old 07-27-2014, 08:25 PM
greg_8507's Avatar
greg_8507
greg_8507 is offline
You have some spots that look like they may not be fixable. But for the most part if you take your time I think you can save your self the expense of replacrment.
The A/C condenser isn't as simple as a radiator. You'll have to reclaim the A/C system, swap it out, pull a vacuum on the A/C system, and then re-charge it to the proper level.
Old 07-27-2014, 08:27 PM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
I have seen some dog combs that would straighten those fins a little too.
Quick Reply: Towing -newbie
