Sponsored by: Real Truck
Brake Problem. Please Help.
Old Oct 7, 2014 | 08:20 AM
  #46
jimalbert's Avatar
jimalbert
I can only assume that they changed the hydraulic control unit (thats what they told me) because they said the one they ordered and originally installed had a bad motor. The electronic ABS unit wouldnt have a motor. I even asked them if they completely flushed the system before installing the new one because thats what the service bulletin says to do so you dont take the chance of crap being in a line. I dont know.. they want to have a call between the GM of the dealership and the service manager today to discuss it. Either way a ton of crap has been done that wasn't necessary, and I have been without a vehicle for quite some time. Bottom line is i need that truck for this weekend as I am traveling to my hunting cabin and road sometimes road conditions dont permit the use of a passenger car. Not only that, i dont exactly want to put chainsaws, chop saws, tools etc.. in my van.
Old Oct 7, 2014 | 08:42 AM
  #47
Big-Foot's Avatar
Big-Foot
Jim, I think you are completely in the right here... Ford needs to step up for this!
Have you discussed this with your insurance agent to see if there may be remedies from that angle? Possibly coverage of a rental unit?
Old Oct 7, 2014 | 09:05 AM
  #48
jimalbert's Avatar
jimalbert
Yesterday the dealership finally offered me a vehicle. I may take them up on it but I doubt that they have a truck laying around that they're going to give me to take to my hunting cabin. I havent personally called Ford yet, i will hear what the GM and service manager have to say today. Its a good thing i documented everything under the sun that they told me since the first day I called for answers because no one called me.
Old Oct 7, 2014 | 10:47 AM
  #49
jimalbert's Avatar
jimalbert
Well, they didn't call as they said they would... Completely Frustrating.
Old Oct 7, 2014 | 03:01 PM
  #50
jimalbert's Avatar
jimalbert
Well, now the service department calls me to ask if I adjusted the push rod between the master and vacuum booster. I said no why would I? And why would that cause you to have brakes on one startup and none on the next. Then he started saying that they have been in contact with ford and ford mentioned that the rubber brake hoses could have been blown up in the inside not allowing fluid to flow. Doesnt make sense either. What a joke.
Last edited by redford; Oct 7, 2014 at 05:02 PM. Reason: Removed reference to legal action.
Old Oct 7, 2014 | 05:03 PM
  #51
redford's Avatar
redford
FTE Leadership Emeritus
Discussing legal action is against forum rules.
Old Oct 7, 2014 | 05:11 PM
  #52
jimalbert's Avatar
jimalbert
point taken. Didnt realize it was an issue.
Old Oct 13, 2014 | 08:33 AM
  #53
jimalbert's Avatar
jimalbert
UPDATE: Truck Finally Fixed.
Well, after 21 days at the dealer the truck is fixed. They told me they were on the phone with Ford engineers for 2 days until they figured it out. It turns out it was the booster. The ford engineers told the tech's that switching it out wouldn't fix the problem and they bench tested the booster and it fell within specs but when they replaced it, the problem was corrected. The only thing i can think of is could the booster have been "over boosting", applying too much assistance. I dont know but I know it works. The service manager settled up with me in a pretty fair way. I only paid for what he originally charged me. So koodos to them in respect to that. I got home and the truck looked like crap so I started washing and detailing it and found that the right front centercap must have been extremely hot at one point while they had it because all of the chrome is bubbled and starting to peel off and there was so much grease and fingerprints on the kick panels and seats that I spent all day doing a wash/detail/interior clean. Thank you for all of the help throughout this process.
Thanks,
Jim
Old Oct 13, 2014 | 09:01 AM
  #54
Big-Foot's Avatar
Big-Foot
Glad you are back on the road again Jim.. What an ordeal!
Too bad that their techs did not clean up after themselves. That's what you pay a "Shop Supplies" charge for - cleaning materials and shop rags etc..
Curious about that bubbled chrome... They must have really hammered it pretty hard to get those brakes that hot..
Old Oct 13, 2014 | 09:14 AM
  #55
jimalbert's Avatar
jimalbert
Here are a few pics. I know they replaced calipers and stuff but they told me during the last stages that they replaced another and it definitely the right front.
Thanks,
Jim
Old Oct 13, 2014 | 09:20 AM
  #56
Big-Foot's Avatar
Big-Foot
Wow... Hopefully they replaced the pads as well... You get the brakes that hot, you glaze (damage) the pads.. You might want to put a dab of silver RTV silicone at the 12-3-6-9 O'clock positions where that center cap touches the wheel. The cap is only plastic and it has likely lost some strength in its retention tabs.. If you do it right, it will be hard to tell.. You probably want to double check the torque on the lug nuts anyway. I know I would..
Old Dec 10, 2014 | 04:40 PM
  #57
AK3500's Avatar
AK3500
Follow up Question
Hey Jim! What did you find out was your problem? I just bought an 04 250 with the 5.4 and I started having EXACTLY the same problem on mine yesterday. Everything looks okay so far, but I haven't had time to do any serious examination. I was already thinking the master cylinder since I don't ever seem to lose the "power" side of the equation. I do know that the rear main line was replaced at some point in the past, but no leaks and the reservoir is full.
Old Dec 10, 2014 | 10:05 PM
  #58
AK3500's Avatar
AK3500
Oops...nevermind
Don't know how I missed it, but just saw that you had already answered my question!! Thanks again...
Old Dec 11, 2014 | 10:57 PM
  #59
AK3500's Avatar
AK3500
Update to my problem
R2 the booster today...zero change. Now thinking the master cylinder, hoping it's not the ABS module! I discoed the lines out of the master and plugged the holes. According to AllData, if the master cylinder is bad, with the holes plugged, the pedal will go to the floor, which it does. Fingers crossed...I'll put the new master cylinder on tomorrow and get some nice new fluid in the system as well
fl-mitchells
16
Mar 15, 2013 01:43 PM
Nseal1996
Jun 25, 2012 02:59 PM
troubledford
Oct 18, 2010 07:41 AM
There Goes The Neighborhood
May 10, 2005 08:43 AM
rockcrawl86
Dec 3, 2003 02:21 PM
