rock crawl
Old Dec 3, 2003 | 02:14 PM
rockcrawl86's Avatar
rockcrawl86
Talking rock crawl
I have a 86' ford 150. i'm only 17 and its almost completly stock. i have a problem though. my from brakes dont work anymore and when i drive it makes a scratching noise. what is it ,how much is it going to cost and how do i fix it
Old Dec 3, 2003 | 02:21 PM
locknkey's Avatar
locknkey
Your Rotor could be rubbing with the pads.....no pads, no brakes, also have you checked the fluid in the Brake Master Cylinder? There is two bowls in the Master Cylinder, the one thats facing you after you take it off is for the Rear Brakes, the one in back (which is normally larger than the front) is for the Front Brakes, each is indepentant of the other, But is you have NO Brakes, with engine running, the master cylinder....
