Amb. temp screen quit working
Old Jul 24, 2014 | 01:39 PM
Courtney Williams's Avatar
Courtney Williams
This happend a few years back when I bought the truck but it seemed to fix itself after a few cycles. This time it wont come back. The screen on my 06' that showes the outside temp has quit working, but if I push A/C or heat the screen comes up and stays as long as one or the other is on. Is this fuse? Or do I have other issues.
Thanks,
Old Jul 24, 2014 | 01:45 PM
David7.3's Avatar
David7.3
Doubt it's a fuse, but you can look Sounds like another typical ford, Yea lets hook something else up to a computer.
Old Jul 24, 2014 | 01:50 PM
Courtney Williams
Yeah its always done a few weird things electrically since I bought it. Drive's me crazy. If it's not a fuse where should I look?
Old Jul 24, 2014 | 02:42 PM
fordboy2's Avatar
fordboy2
I think it's common for the displays to go bad on the climate control, but if thought it was all or none.
Old Jul 24, 2014 | 02:46 PM
jsm180's Avatar
jsm180
If you have power to it, send it here. There are several chips inside that can have poor solder joints. Mine had one chip missing completely. $25 and quick turn.
http://www.ebay.com/itm/FORD-F150-F2...-/331100519801
Old Jul 24, 2014 | 02:49 PM
Courtney Williams
Thanks, It says overhead console, but mine is below my stereo. I'll send him an email and see if he can still fix it
Old Jul 24, 2014 | 03:02 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I believe Ed is starting to fix read-outs and iTBC modules.
Josh
Old Jul 24, 2014 | 08:19 PM
Misky6.0's Avatar
Misky6.0
Thanks,
More info required..
If you have manual, *****, for your a/c system, you are talking about the lie-o-meter in the overhead display.
The electronic (eatc) automatic a/c system has a digital display built in which shows ext temp.
The eatc system has an ext temp button to control what temp is displayed.. when off, the display is blank, unless you select ext temp.
It is remembered, provided you don't disconnect batteries!
The overhead display is easily fixed by resoldering a few resister packs that fall off from a hot roof being so close.
Hope this helps...
Sent from my Sprint PC36100 using IB AutoGroup
Old Jul 25, 2014 | 01:47 AM
Yahiko's Avatar
Yahiko
Josh
Yes Ed said he was but said to drop him an Email if you want info.
Also try this. When it out and the EACT is off push the OAT button
and see if it comes back on. If it does then it was just set on inside
set temp display. With the system off there is nothing to display
so it blanks. Mine was blanked after all the work I just did and I got
to playing with it and found that with the system off you hit that
button and it would blank out if not displaying the OAT (Outside Air Temp)
Sean
TDGRIND
Electrical Systems/Wiring
Oct 20, 2009 06:51 PM
got_zuk
Aug 16, 2006 01:24 PM
vix
Dec 17, 2003 09:43 AM
