Temp (HVAC) controls dashboard light
Old Dec 16, 2003 | 06:34 AM
vix's Avatar
vix
Question Temp (HVAC) controls dashboard light
Sup, guys...
just got myself a 1999 Explorer Sport 4x4, an awesome vehicle!
One problem though - the HVAC/Temperature/FAN controls don't light up at night, i.e. all the dashboard lights are on except the temp control ones. This my first Explorer and I haven't seen the fuse wiring diagram, but will this problem be because of:
1) faulty fuse in the fuse box
or
2) plain light bulb failure behind the controls?
any ideas?
cheers..
Old Dec 16, 2003 | 10:16 AM
87 XLT's Avatar
87 XLT
Take a look at the fuse page in your owners manual. Is anything else thats wired to that fuse also not working?
Old Dec 16, 2003 | 11:06 AM
vix's Avatar
vix
i haven't looked at the fuse box yet, but everything in the cabin seems to operate OK... Can a single fuse be dedicated for the HVAC lights? I thought it'd share it with smth else...
the mirror puddle light on the driver side isn't working, but I think that's just a burn out bulb..
Old Dec 16, 2003 | 11:30 AM
87 XLT's Avatar
87 XLT
If anything else thats wired to that same fuse IS working, then you know it's not a blown fuse, just a bad bulb. BTW, whats a "mirror puddle light"?
Old Dec 16, 2003 | 04:54 PM
nulife's Avatar
nulife
Hi there!
I recently bought a 1998 Ford Explorer XLT - 82,000 Miles. I have the same problem. Half of my display window (i guess that's what you call it) is out and the other half is on. I haven't checked the manual to see if it's a fuse, but I will check. I also noted that the display for the CD/radio/cassestte player (factory) is out. Please keep me updated on your progress!!! Good luck!!
Old Dec 17, 2003 | 06:42 AM
vix's Avatar
vix
well, I checked the fuse and it's responsible for other lights that are in working condition. I forgot which ones exactly but some radio control lights, etc... It's fuse N10... I pulled it out anyway - it's ok, so it's obviously the bulb or bulbs, it's probably two of them... Now I'm thinking about how to get to those lighs behind the "AC/heater assembly" - that's what they call it in the manual.
Do you guys/gals think it's enough to take the middle console face plate off to get to it? Or it's necessary to take off the whole dash?
oh, and the puddle light is a light bulb which is inside the outside mirrors, it's installed at the bottom of the mirror and illuminates when you unlock the car. I guess it's one of those luxiry things, sort of a pathway illumination...
Old Dec 17, 2003 | 08:11 AM
mason's Avatar
mason
Vix - Get yourself a Haynes manual. It shows how to remove the middle console face plate as well as other interior parts. It's not difficult but the pictures and instructions in the manual are much better than trying to explain on this forum.
Nulife - the radio display problem is likely unrelated to your other light problems. Search this forum for radio display problems or check out this website: www.shareamemory.com/radio
Mason
Old Dec 17, 2003 | 09:07 AM
vix's Avatar
vix
good call, mason, found one in borders, will check it out later..
cheers
Old Dec 17, 2003 | 09:43 AM
nulife's Avatar
nulife
Thumbs up 98 Ford Explorer
Thank you both for your help. It would appear that the factory CD/cassette/radio display is a well document topic. I've searched a few other places and this is apparently the problem:
http://forums.vmag.com/pm-1199b/messages/2792.html
Thanks again for all of your help!!
Vix - good luck!
Brian Skinner
Aerostar
Dec 30, 2014 03:17 PM
LARIAT 85
Nov 14, 2011 12:54 PM
0rion
Electrical Systems/Wiring
Nov 8, 2007 06:47 PM
coolgreen
Mar 10, 2003 04:48 AM
