Clutch pedal??
Old Jul 17, 2014 | 10:44 AM
Little_ranger86's Avatar
Little_ranger86
Clutch pedal??
I have an 86 ford ranger and its an2.9 5 speed. The clutch starts engaging right at top. Is therenany way to make it engage closer to the floor?
Old Jul 17, 2014 | 11:49 AM
Hank85713's Avatar
Hank85713
bleed the system is about all you can do. Maybe check see if there mechanical linkage on the clutch rod, dont know about your system. I know my 89 F250 had an external slave so that may be a problem area to check if ya do.
Old Jul 17, 2014 | 09:53 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
Make sure your hydraulic clutch reservoir is full of fluid. Check for leaks around the cylinder near the clutch pedal. There is another cylinder inside the transmission bell housing that could leak. Check for clutch fluid leaking from the bell housing at the bottom.
Old Jul 17, 2014 | 10:27 PM
Hank85713's Avatar
Hank85713
From the autozone site, the truck has an external slave cylinder, should be on the left side of the transmission. If its never been changed this may be the time to do it. also check the master cylinder it may be bleeding off and not holding pressure. as noted above check for wet carpeting/mats inside to see if leaking. Check the slave for visible leaks. More than likely you will need both particularly if you only replace one, the other normally follows soon after.
Old Jul 17, 2014 | 10:34 PM
drb1956's Avatar
drb1956
Clutch?
First, how many miles on this vehicle? When, if ever, has the clutch been replaced?
Old Jul 18, 2014 | 11:22 AM
Josh S's Avatar
Josh S
Do you mean all the clutch action is happening when your foot is almost completely off the pedal? If so, mine is the same way and I've been trying to think it out. To me it seems like the fact that the clutch is releasing the transmission right away indicates the fluid is good with no air in the line. Otherwise it would take a lot more pushing before the slave could do its job. Is that right? My guess has been the problem is related to a weak connection between the clutch plate and pressure plates, caused by one or both being worn out or the pressure plate mounting bolts having come loose. Hopefully you guys can help me understand this better. Hydraulic clutches always seem backwards to me compared to cable operated.
According to TRS you have a Mitsubishi FM145 transmission which has an internal slave cylinder. That sounds right as my '88 has the later FM146 with internal slave.
This problem has been a bother to me as there's not much pedal range between engaged and disengaged. My other Ranger has the M5OD which begins engaging more in the middle of pedal travel so seems to provide a much smoother transition.
reamer
Jul 12, 2016 01:45 PM
fluidp
Jan 10, 2014 09:41 PM
chrisginco
Sep 3, 2012 07:53 PM
wickedklown83
Mar 13, 2010 12:56 AM
NWO_diesel_nut
Sep 14, 2008 03:16 PM
