351m/400 351c
Old Jul 16, 2014 | 07:15 PM
Bud Mud's Avatar
Bud Mud
351m/400 351c
i know nothing about the 351cleveland...........AT ALL. Do parts interchange with the 351m/400? heads,trans bolt patten, block? THANKS
Old Jul 16, 2014 | 07:27 PM
Jklnhyd's Avatar
Jklnhyd
https://www.ford-trucks.com/forums/s...d.php?t=102632
This is a sticky at the top of this forum. Read it and then maybe ask questions from there.
Old Jul 16, 2014 | 07:39 PM
fordcrzymike's Avatar
fordcrzymike
The 351M and 400 are basically the same engine. The main differences have to deal with the stroke. The 351M has a 3.5" stroke while the 400 has a 4", therefore, the cranks are different. The 400 also has shorter pistons so that they do not crash into the head. Another small difference is the clutch. The 400 has a 12" while the 351M usually has an 11". The 351C is similar, but it has roughly a 1" shorter deck height. There is plenty of info on google....
Old Jul 16, 2014 | 07:48 PM
slowrollerzcustoms's Avatar
slowrollerzcustoms
my truck had the 400 in it damn thing was a beast
Old Jul 16, 2014 | 07:52 PM
6t6merc's Avatar
6t6merc
It is easier and cheaper to change an "M" motor into a 429-460 than into a Cleveland. Read a bit about it, as suggested above. If your truck were a year older you'd have a much better motor in it direct from Ford, but that is only wishing...
Eric
Old Jul 16, 2014 | 07:54 PM
fordcrzymike
I'm building this beast at the current moment. 400 bored .040 over to 410ci. Comp cams extreme energy cam (right under .500 lift) Keith Black flat top piston (C/R~9.2), Wieland dual plane aluminum intake, edelbrock 1806 650cfm carb, MSD blaster 2 coil, flowtech long tubes, etc.
Hopefully it'll be running this weekend.
Old Jul 16, 2014 | 07:56 PM
slowrollerzcustoms
That is going to be Nasty
Old Jul 16, 2014 | 08:01 PM
slowrollerzcustoms
This is going into my 78
Old Jul 16, 2014 | 08:06 PM
fordcrzymike
Eric
Not sure what you mean by "change a M motor into a 429-460
The 429 and 460s are 385 series engines while the "M" motor is a 335 series. They are totally different engines.
Old Jul 16, 2014 | 09:15 PM
6t6merc's Avatar
6t6merc
Yes, I know. What I mean is that it easier to bolt a 429-460 into the space vacated by the execrable "M" than it is to put a Cleveland in there.
Eric
Old Jul 16, 2014 | 09:38 PM
fordcrzymike
Eric
Yes, they share the same bell housing bolt pattern as the 351M and 400.
Old Jul 17, 2014 | 06:06 AM
Bud Mud's Avatar
Bud Mud
i know about the 351m/400,will heads off a 351c bolt on a 351m 400? Im basically searching for parts or a complete 400 to rebuild while im driving my truck that has a 351m. I can find lots of 351c parts in my area plus 460 but nothing in a 400. THANKS guy's.
Old Jul 17, 2014 | 07:15 AM
redroad's Avatar
redroad
by 351C head, which do you mean; U.S. production 351C 2V, U.S. 4V open chamber, U.S. 4V closed chamber, or the Australian production 302C closed chamber head?
read this thread
Green Streak
Jan 6, 2005 06:35 PM
fordeverpower
Dec 1, 2003 12:14 AM
aj5601
Sep 21, 2002 03:46 AM
J.B.L.
Aug 16, 1999 12:09 PM
