dead accelerator pedal?
Old Jul 15, 2014 | 02:50 PM
2andfour's Avatar
2andfour
Help! Fired up the truck, no problem....put my foot on the accelerator, and the pedal went straight to the floor!
Does anybody have a diagram of the cable linkage? I need to get on the road tomorrow.....it's a '90 E350
thanks!
-k
Old Jul 15, 2014 | 04:03 PM
ihateminimumwage's Avatar
ihateminimumwage
Sounds like the throttle return spring broke, or something in the linkage may have fallen off. Pop the hood or take the doghouse off an take a look in there. Should be fairly obvious.
Old Jul 15, 2014 | 11:02 PM
bduemig's Avatar
bduemig
The cable runs directly from the top of the accelerator pedal to the firewall. If you look at the firewall from the engine compartment you will see a black cable coming out and running toward the passenger side. On mine, it curves just in front of the turbo and heads toward the IP. I recently replaced mine because the sheave inside the spring on the cable itself had disintegrated and I got very little response from the pedal.
Old Jul 17, 2014 | 12:57 AM
mstreman's Avatar
mstreman
I had an issue with the accelerator cable going dead. Two areas: atop the accelerator pedal arm is a "V" notch that cuts into the small circular cable opening. The rubber bushing that was there originally tends to fail. Look behind the notch and if the bushing is gone, locate the very rear washer surrounding the Acc cable at the firewall. Move it in front of the notch on the pedal such that the pedal now has something to keep keep everything else from just slipping through the hole the notch connects into.
Item two the actual throttle connection clips onto a ball stud. Just behind this housing is a plastic tube 1 inch extension into the spring and slips over the engine end of the throttle cable. (THis needs silicon lube both outside the housing and down the cable train) This plastic extension tends to break off with age. When it does the lip of the cable housing sometimes jams and overrides the spring. Clean the edge if is long enough to minimize that from happending. If all else fails the throttle assembly is around $45 at O'Rileys ( just bought one)
Old Jul 17, 2014 | 10:25 PM
Macrobb's Avatar
Macrobb
I had this happen, and my long-term solution has been to just get in there with a pair of plyers and break out that plastic extension -- it's totally not needed. Without it, though, the small return-spring won't push against anything, and you'll only have the main IP spring for a return. This makes the pedal a little weaker, unless you grab a stiffer spring to replace that main spring.
I've been running that way for many months; it's worked great.
Old Jul 21, 2014 | 10:36 PM
Macs1964F100's Avatar
Macs1964F100
I fixed my cold start sensor last night and turned down the idle. Now the red end of the hangs on the extension inside of the spring.
I am going to try filing a bevel on the extension to keep mine cable from hanging on it. I that does not work breaking the extension sounds like a good idea.
Christopher Workman
Mar 12, 2024 05:40 PM
AKHunter93
35
Dec 19, 2015 06:02 PM
biga17133
Sep 25, 2007 02:29 AM
raycgl
1983 - 2012 Ranger & B-Series
Apr 28, 2004 08:51 PM
frachubb
Bronco II
Oct 19, 2003 08:33 PM
