Deletes!
Old Jul 16, 2014 | 08:19 PM
JOHN2001's Avatar
JOHN2001
Yeah... You're not driving a 6.0 or a DPF or EGR equipped diesel. All the deletes you would want to do Ford and international did you the favor and never put that junk on.
With the intercooler tube... The driver's side has a tendency to rub on the square nut on the power steering pump you'll most likely have to pull the tube to see what I'm talking about check it, fix it and be done with it.
When you're done with that stop trying to fix a good thing, if you have a question... Ask. From the sounds of it you'd delete the turbo if someone told you it was a good idea
Old Jul 16, 2014 | 08:24 PM
Pikachu's Avatar
Pikachu
I had a problem with that stupid corrugated plastic wire wrap nearly eating through the right side CAC tube. The heater hose I installed the ball valve in was wrapped in the stuff. You can see the marks on the tube, and it's hard to tell from a photo but it's pretty deep. It wouldn't have been much longer before it went right through.
Sous
20
Jan 2, 2025 02:31 PM
Dave042
20
Feb 12, 2019 02:20 PM
B_Allen
Apr 11, 2013 07:46 PM
Texas Chain Ring
35
Feb 16, 2013 07:44 AM
yamahahauler
Jan 10, 2007 05:30 PM
