speed sensor test
Old Jul 13, 2014 | 02:02 PM
eckart's Avatar
eckart
speed sensor test
Im working on my sons 98 4.0 auto 4x4 ranger, Is there a way to test a trany speed sensor. Just put in a rebuilt trans and im getting p0720 code speed sensor malfunction and the od light flashes.
Old Jul 13, 2014 | 04:33 PM
pawpaw's Avatar
pawpaw
My 99 rear differential replacement speed sensor measured 1.9K ohms across the sensors two electrical contacts. The old one was intermittent open circuit.
Old Jan 7, 2015 | 07:55 PM
pie eater's Avatar
pie eater
hi there. have you checked the wiring to the sensor, and made sure its not rubbing and shorting to the body? i would imagine the the sensor should be reading a couple of hundred ohms resistance.
i have the exact same code on a mazda b3000 i have just bought, but this will not shift gears, and the speedo was reading the speed wrong. i was reading earlier and also email another member, and i have found out that a bad plug wire, or plug, leaking ac volts to the engine, and a bad diode in the alternator,or a poor ground can cause the same code. please let me know what you find. good luck, from a frigged rosetown sk.
Mike0929
1997 - 2003 F150
Dec 9, 2016 12:38 PM
chris1996
Oct 10, 2016 09:28 PM
skyfox10
Modular V10 (6.8l)
Apr 14, 2014 08:06 PM
Explorer98
May 30, 2006 08:36 AM
nanufree
Dec 19, 2005 12:33 PM
