Sponsored by: Real Truck
Adding a remote trans filter on a 08'
Old Jul 13, 2014 | 12:02 PM
Denola's Avatar
Denola
I used to own a fleet of school buses and I had remote trans filter on all of them. I'd change the filter about every 10K and felt like it really extended my trans life on Allisons. I wanted to put on my SD, so, I had a spare filter block with a 20psi bypass valve, and I used it. Worked out real well mounted to the radiator support, up front--easy access. uses a NAPA 1268 filter. In the picture it looks like the hoses are real close to the AC condenser, but in real life, the are three inches from it.
Old Jul 13, 2014 | 05:46 PM
pappy19's Avatar
pappy19
Very nice install. I did a similar with a $40 kit from Summit Racing on my 2008 V-10.
Old Jul 13, 2014 | 06:38 PM
Denola's Avatar
Denola
Pappy, we basically did the same thing---the only real difference I can see, is that, I used the bottom line (which is the hot line before the fluid is cooled), and you filtered it after it has been cooled. I can't see it would make much difference, but I was trying to keep any foreign matter from going through the cooler. I had about everything I needed on hand, so, the cost of the filter was about it, Dennis
jawdoc
Jun 29, 2014 08:07 AM
koski19
May 7, 2013 07:58 PM
Hondaonda
Feb 9, 2012 07:42 PM
Dan Robertson
Escape & Escape Hybrid
Mar 29, 2008 12:08 AM
Stinger_916
Nov 13, 2003 05:29 PM
