Remote Trans Filter Install
Old Feb 5, 2013 | 08:21 AM
koski19's Avatar
koski19
Morning Guys,
I have a remote trans filter setup from derale. If anyone has a remote filter setup where did you install it? How do you like it?
Jeff
Old Feb 5, 2013 | 08:48 AM
mueckster's Avatar
mueckster
I installed mine behind the bumper near the frame and patterned the setup after this: SpringerPop's Transmission Filter I used a different plate & hardware for mounting and changed up the fittings to suit my needs. I used two different size hose barb fittings to act as one of the adaptors for my 6.0 trans cooler install. It fits well in that location and is easy enough to access for changes. Pictures may be decieving, but I am able to remove the filter without removing any braces.
Pics from my install:
Size:  96.1 KB I put on the tape temporarily to protect the filter during test fitting.
Old Feb 5, 2013 | 08:54 AM
clux's Avatar
clux
The color of that filter looks suspicious, you sure you didn't put the tape on to conceal your use of a Fram?
I have Bob's transmission filter kit mounted to the frame by the transmission.
Old Feb 5, 2013 | 10:11 AM
grec-o-face's Avatar
grec-o-face
That's what I was thinking.
Old Feb 5, 2013 | 06:31 PM
mueckster's Avatar
mueckster
Yep, it's a Fram (HP1). It came with the filter housing. I still stand by my reason for the tape.
Old Feb 6, 2013 | 08:09 AM
koski19's Avatar
koski19
Thanks for the replies...I'll be installing next week.
Jeff
Old Feb 6, 2013 | 08:28 AM
trekbasso's Avatar
trekbasso
Jeff
I will second the Diesel Site kit. It is mounted out board of the frame, but several members have used it (I am sure many more) without issue. Almost two years here and no problems.
I do like the idea of tucking it behind the bumper though.
Old May 7, 2013 | 04:47 PM
VEGA006XX's Avatar
VEGA006XX
I have the BPD oil cooler upgrade that relocates the oil filter to the driver side wheel well behind the bumper. It works great, and comes with a nifty gaurd that mounts to factory holes. Anyway i mirrored the gaurd for the passenger side wheel well and plan on putting my coolant bypass and trans bypass behind it as well. I have the XDP kit but can not mount it in the location it was designed for because i have the BD POWER air/oil separator kit installed there.
Anybody know where i can get just the remote filter bracket for the trans?
I have the ability to make my own mounting bracket and hoses/lines at work
Old May 7, 2013 | 05:11 PM
SpringerPop's Avatar
SpringerPop
Take lots of pictures of your handiwork! We wanna' see it!
Amazon has the Trans-Dapt base:
Trans-Dapt 1028 Single Filter Relocation Bracket : Amazon.com : Automotive Trans-Dapt 1028 Single Filter Relocation Bracket : Amazon.com : Automotive
Pop
Old May 7, 2013 | 07:58 PM
VEGA006XX's Avatar
VEGA006XX
Thanks Springerpop, thats what i thought just wanted to make sure it would be the right size.
Pictures are on my list of things to do lol so ill be adding those soon.
Thanks again
Denola
Jul 13, 2014 06:38 PM
F250racer
Oct 21, 2010 11:55 AM
jenkins2
2004 - 2008 F150
Mar 8, 2009 07:28 PM
TrvlnP8
Sep 25, 2005 04:39 AM
Stinger_916
Nov 13, 2003 05:29 PM
