Sponsored by: Real Truck
transmission fluid
Old Jun 29, 2014 | 07:10 AM
jawdoc's Avatar
jawdoc
transmission fluid
2008 f250 auto
is the trans filter change possible?
i didnt see this in the tech folder and no videos for a 2008
Old Jun 29, 2014 | 08:07 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, it's possible.
There was a running change in 2008. The first part of the year the trans had both an external and internal filter. The external filter needs to be changed, the internal filter does not. After the change the external filter was eliminated and the internal filter was improved. These filters also need to be changed.
The easiest way to tell what you have is to get under the truck and follow the cooler line from the rear of the trans. See if it goes directly to the radiator or if there is a filter in the line.
speakerfritz
Jul 24, 2014 08:59 AM
djed
34
May 29, 2014 02:41 PM
hink10
Aug 6, 2006 11:58 PM
dslbrnr
Sep 15, 2004 12:22 PM
