Sponsored by: Real Truck
Remote External BM Transmission filter
Old Sep 1, 2011 | 06:26 PM
Hondaonda's Avatar
Hondaonda
I posted this in the Excursion fourm also.
I had a couple questions on external filters. I was thinking of adding a BM Remote Transmission filter kit w/ a WIX 51622 Transmission filter and a Magnefine Forcefield Pre-Filter after my cooler. I know I need to watch my flow rate should I be worried about having to much restriction with what I am looking at or just stick with the normal in-line Magnefine filter after the transmission.
The truck was purchased used w/ 136k miles and a rebuilt ford transmission ( don’t know when but has the ford rebuilt sticker still on it w/ barcode ) and 6.0 cooler already installed w/ a inline Magnefine filter post cooler.
Old Sep 6, 2011 | 05:55 PM
Hondaonda's Avatar
Hondaonda
Bump.
Anyone ever thought of doing this or actualy done it ?
Old Feb 9, 2012 | 07:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I've never done anything like this. After installing it you need to check the flow rate.
Get two containers. Remove the line going to the rear of the trans. Put the line in one container. Have someone start the truck, leaving it at idle and in park. Once the flow is steady move the line to the second container for exactly 15 seconds and then move it back to the first container. Shut the engine off.
If fluid sprayed out of the transmission where the line is disconnected it fails the flow test. If there is less than a quart of ATF in the second container it also fails.
If the test fails remove the filter and get rid of it.
Old Feb 9, 2012 | 07:42 PM
Hondaonda's Avatar
Hondaonda
Thank you so much, I will have to give this a try. Ill do it with the old trans fluid to make sure it works on the above test when flushing - then switch to a new filter after its flushed.
This will be a 2 filter test. Ill post the results in case someone else wants to give it a try.
The theory for this a few things
1. Extra cooling via the filter ( probably a 5-6 degree drop )
2. Extra filter fords is like a pass through from what I have read.
3. Change the extra filter every 10k or so miles and the Magnefine will catch all metal flakes in theory.
Or am I just way over complicating/thinking things ? I have heard so many bad things about the 4R100 and wished I had a torqueshift 5r110 it is a much better transmission. I purchased the truck used with 136xxx miles and it already had a rebuilt transmission so this multiples my fears.
M-S-G
22
Aug 15, 2016 10:11 PM
speakerfritz
Jul 24, 2014 08:59 AM
Dan Robertson
Escape & Escape Hybrid
Mar 29, 2008 12:08 AM
JOE-M
19
Jul 6, 2005 10:01 PM
Stinger_916
Nov 13, 2003 05:29 PM
