2004 Sport Trac multifunction switch
Old Jul 13, 2014 | 09:10 AM
w5kgt's Avatar
w5kgt
Hey guys, I'm in need of the pin-out for the multifunction switch. The high beam is stuck on and the switch seems to be clicking and feels good. But I would like to check it before I buy a new one. I have it out and can't find a pin-out. Thanks
Old Jul 13, 2014 | 01:31 PM
87 XLT's Avatar
87 XLT
It's a long shot that yours is the same, but heres the test for my 97 Explorer. Connect ohm meter to pins 196 & 632 closed circuit when switch is in high beams position.
Connect ohm meter to pins 15 & 13 closed circuit when switch is in low beams position.
If the high beams went off when you removed the connector I think you've found the problem.
pins 44 & 374 closed circuit when switch is set to left turn.
Old Jul 13, 2014 | 10:32 PM
shorod's Avatar
shorod
See if this gets you what you need.
-Rod
Old Jul 15, 2014 | 06:22 PM
w5kgt's Avatar
w5kgt
Thanks
Thanks Rod, that's just what I needed. Checked the switch, and yes it is bad. Jumped the connector for low beam and high beam and they both work. Set it back on low beam and ordered a new one. Thanks again.
Old Jul 15, 2014 | 08:39 PM
w5kgt's Avatar
w5kgt
Thanks
Old Jul 15, 2014 | 10:14 PM
shorod's Avatar
shorod
Glad I could be of assistance and you were able to get the problem properly diagnosed. Good work!
-Rod
Big-Red-Lariat
2009 - 2014 F150
Jun 22, 2014 02:05 PM
jmonin2
Mar 24, 2011 09:49 PM
fordman363
Aug 31, 2006 01:16 PM
OKFords
1978 - 1996 Big Bronco
Jun 30, 2003 09:51 PM
ckrichard
Electrical Systems/Wiring
Oct 15, 2002 07:35 PM
