no headlights
Old Mar 20, 2011 | 11:15 AM
jmonin2's Avatar
jmonin2
no headlights
i have a 97 explorer the other day i lost both headlights. the high beams only work in the momentary position, but dont in the set position. i still have parking, brake, and dash lights. does anyone know if this is the headlight switch or the multi-function switch?
Old Mar 20, 2011 | 08:15 PM
shorod's Avatar
shorod
I would vote for the multi-function switch.
-Rod
Old Mar 24, 2011 | 01:45 PM
87 XLT's Avatar
87 XLT
Testing the multi switch is simple enough.
Remove the electrical connector & connect your ohm meter to terminal 196 & 632. The circuit should open/close each time you operate the switch.
For low beams connect to terminal 15 & 13 & operate the switch.
Old Mar 24, 2011 | 08:58 PM
shorod's Avatar
shorod
I believe there have been a few others who have found wires/terminals that broke and/or pulled out of the connectors to the multi-function switch as well.
-Rod
Old Mar 24, 2011 | 09:49 PM
One Sock's Avatar
One Sock
-Rod
I once had a pulled-out connector. Fixing it was an easy zero-dollar repair.
dmp1983
Nov 4, 2012 11:28 AM
5xkmw
Dec 26, 2007 09:30 PM
rvdealer
1997 - 2003 F150
Sep 11, 2007 09:29 AM
Dutch123
1978 - 1996 Big Bronco
15
Feb 23, 2007 08:36 AM
FordF150_1996
Apr 2, 2005 03:12 PM
