oil leak
Old Jul 12, 2014 | 04:19 PM
Edogsf350's Avatar
Edogsf350
oil leak
I'm looking for suggestions on common oil leaks.
A friend of mine has a 03 7.3 with under 150k milage. he has a oil leak in the valley of the engine. it doesn't leave a big puddle but none the less it leaves a puddle.
any suggestions would be helpful .
Old Jul 12, 2014 | 04:25 PM
Pikachu's Avatar
Pikachu
Turbocharger pedestal o-rings, EBPV actuator, HPO lines, HPO pump are all candidates for leaks. Clean the valley with degreaser and watch to see where it comes from. If cleaning the valley isn't an appealing task, he could put some UV dye in the oil and see where it leaks from first with a UV flashlight.
Old Jul 12, 2014 | 04:29 PM
Edogsf350's Avatar
Edogsf350
thanks for responding so fast. i recommended those suggestion to him, as well as the UV light test. looking at it its wet from the front ( oil res ) running to the rear due to the incline of the engine.
Old Jul 12, 2014 | 05:41 PM
Pikachu's Avatar
Pikachu
One thing to pay particular attention to is the HPOP. There's a "non-serviceable" plug on the underside of it that's been known to leak. There is a service kit for the plug through a couple sponsoring vendors here, if that turns out to be the problem.
mlbbaseball
Mar 25, 2014 08:10 PM
bow4elk
Apr 19, 2008 04:14 PM
RCFORD
Jul 3, 2007 05:12 PM
Double AA
Feb 22, 2007 01:14 PM
88f1504x4
Mar 16, 2006 10:19 AM
