Help please!
Old Jul 10, 2014 | 05:24 PM
egregg57's Avatar
egregg57
Help please!
Help! changing the differential oil on a 2005 F 350. Cannot find the fill port!! UGH
Old Jul 10, 2014 | 05:32 PM
Super Duty Service's Avatar
Super Duty Service
Former Vendor
Driver side in front of the axle tube. It's a 3/8 drive square plug.
Old Jul 10, 2014 | 05:35 PM
egregg57's Avatar
egregg57
got it awesome!!
Old Jul 10, 2014 | 08:57 PM
egregg57's Avatar
egregg57
So I used guzzles guide to do the change. Even painted the cover. I was expecting the differential to take 9 pints. I bought 5 Mobile quart bottles and even with the truck leaning to the passenger side it would only take about 7. I tend to be a bit OCD..... So that is bothering me.
Is there a reason for that?
Took the truck for a spin. Tight turns in a parking lot, up to 80 mph on the highway and all seems good. There might be weeping at a lower bolt. Don't understand why it might be doing that. Will check in the morning to see if it is an actual leak.
If so, I know what I am doing Saturday. Hope it is a result from overflow.
Not a tough job....fill plug dilemma aside!!
And thanks folks! FTE is great!
Eric
Old Jul 11, 2014 | 07:10 AM
egregg57's Avatar
egregg57
Follow up
So the "weeping" was just a result, everything is tight and dry. Very happy with the results! Going to check fluid capacity for the Differential to figure out if I missed the proper fill, though I can't imagine how I did!
Eric
Old Jul 11, 2014 | 01:45 PM
Zip's Avatar
Zip
Just a thought. Check to make sure the axle vent isn't plugged.
Old Jul 11, 2014 | 01:51 PM
npccpartsman's Avatar
npccpartsman
Eric
IIRC mine has never taken a full 4 quarts to fill it.
Old Jul 11, 2014 | 02:51 PM
egregg57's Avatar
egregg57
All good here!!
Old Jul 11, 2014 | 02:53 PM
egregg57's Avatar
egregg57
Forgot to throw in that I checked the capacity for the DIFF and viola! 7 pints! Right on the money!
Old Jul 11, 2014 | 06:24 PM
bismic's Avatar
bismic
The amount of fluid the differential takes depends on what axle/differential the truck has - per owners manual:
F250/F350 10.5 Axle - 6.9 pints
F350 Dana 80 Axle - 8.5 pints
F450/F550 Dana S110/S130 Axle - 14.0 pints
missouguy
Aug 16, 2011 10:34 PM
JHoffman93
Mar 17, 2010 05:58 PM
currituckF150
Apr 7, 2008 11:13 AM
Tdusseau
Aug 22, 2006 06:01 PM
cchev
Nov 14, 2003 07:42 PM
