fill plug ???
Old Apr 6, 2008 | 12:27 PM
currituckF150's Avatar
currituckF150
fill plug ???
My brother has an 2004 Explorer 4dr with a diff leak from an axle. How do you check & fill diff? I see a large plug & a small plug on cover but none on the housing anywhere. Help!
Old Apr 6, 2008 | 12:32 PM
05 super's Avatar
05 super
maybe that's them. the top plug will be the fill/check one. the bottom will be a drain. take the top one out and feel for oil.
Old Apr 7, 2008 | 09:33 AM
marragtop's Avatar
marragtop
Make sure you read the owners manual and put the correct fluid in.
Old Apr 7, 2008 | 11:13 AM
currituckF150
I pulled the top 1 out w/ the truckjacked up inthe rear & gear lube came out. The plug is @ the same level as bottom of pinion. Just wondering if the dealer or factory overfilled it & thats why its leaking from axle seal.
dracond
Jul 22, 2015 06:08 AM
pdqford
Jun 11, 2011 08:52 PM
mikren
1997 - 2003 F150
Sep 15, 2009 08:09 AM
redchl
1978 - 1996 Big Bronco
Jan 20, 2008 12:12 PM
rb26powered
Aug 3, 2004 02:47 PM
