No Boost-need help
Old Jul 8, 2014 | 10:11 AM
satcom40's Avatar
satcom40
Unhappy No Boost-need help
This morning I had a problem with the truck has I was getting on the parkway for home I press on the pedal and noting no power and then lots of power,
I as I got to the top of the hill it seam to got better but started to over heat. So I slow down and all seam to go back to normal. I look up at my boost gauge and zero no boost. I get home add some coolant and run it in the high idle mode still no boost reading. I check for codes , None.
So it in the driveway what now.
Old Jul 8, 2014 | 02:22 PM
egregg57's Avatar
egregg57
With the truck running, do you have any air leaks? check for that, look at the EBP sensor driverside, near the FICM. Is there an air leak in that area? Might be a dirty or bad sensor.
Why are you adding coolant? Are you losing coolant?
Eric
Old Jul 8, 2014 | 02:32 PM
Money-Pit's Avatar
Money-Pit
Explain "overheat".....what temp did the engine coolant and engine oil get to?
I've never had it happen to me, so I have no idea what the truck will act like..... but the engine will defuel when it gets too hot. I would check on why it's getting hot and losing coolant first, then go from there.
Old Jul 8, 2014 | 08:57 PM
satcom40's Avatar
satcom40
I little more info. Was in panic mode. As i was pressing the throttle my Boost when high 30+ and ECT when to 234 and EOT to 215.
So thinking that the turbo when bad and over boost, possible lifting the head causing the lost coolant. My Mechanic will be back on Morning, going to be a long weekend.
__________________
Old Jul 8, 2014 | 10:55 PM
texans's Avatar
texans
Eric
FYI.. On 04's the EBP was by the T-stat
Sounds like stuck vains on turbo. So did it puke coolant? If so you may have lifted a head.
Old Aug 14, 2014 | 01:43 PM
satcom40's Avatar
satcom40
Got the truck back today. 73 mile test ride ran great. Dave is the Man.
Daves Garage LLC Canterbury CT. New head gasket, EBP sensor, 2 New Exhaust Manifold w gasket, New water pump, Oil cooler 2 New injector for cyl 1 & 7, Upgrade to Studs, Dipstick tube, Glow Plug Harness and New Transmission cooler line. New OIL pan, and a few misc item nuts and bolts. because there was Rust everywhere. Thanks Dave.
hasteranger
Apr 16, 2012 02:27 PM
orange powerstroke
Sep 22, 2011 01:41 AM
jims406rs
Oct 21, 2010 05:44 PM
96bigblueford
Mar 5, 2009 09:05 AM
HugeF350
Jan 21, 2009 10:41 PM
