no boost after coolant flush....
Old Oct 21, 2010 | 04:31 PM
jims406rs's Avatar
jims406rs
I just did a coolant flush with vc9 and now I will sometimes completely lose all boost pressure. If I shut it off and restart it is fine but them after a while will do it again. It's obviously electrical but what would cause this? I did remove the ebp sensor to get to the tstat but it is securely reconnected.
Old Oct 21, 2010 | 04:50 PM
moebdick's Avatar
moebdick
Could the EBP sensor have been damaged when you were changing the t-stat?
Old Oct 21, 2010 | 05:44 PM
jims406rs's Avatar
jims406rs
I don't see how. I simply disconnected it and then reconnected it. Would a bad ebp cause a no boost situation? Wouldnt it cause a cel?
