AC problem...HELP.
Old Jul 8, 2014 | 08:08 AM
Padlock's Avatar
Padlock
AC problem...HELP.
2005 F-250 Lariat (electronic AC control)
My AC is stuck on blowing the high setting. I try to turn it down or even off but it still blows on high. I used to have a problem where it would just quit blowing but if you play with it a little bit it'll start blowing like normal and I still had control. Now it just blows on high all the time. No air is coming out of any other places besides dash vents, it switches to defrost like it should and vacuum pump works fine. What wrong???
Old Jul 8, 2014 | 08:22 AM
Padlock's Avatar
Padlock
It also has a brand new compressor
Old Jul 8, 2014 | 08:33 AM
Padlock's Avatar
Padlock
Well now I took out the blower relay and put it back in but now it won't blow at all. Brand new relay.
Old Jul 8, 2014 | 08:38 AM
69cj's Avatar
69cj
Sounds like the fan speed resistor bank has taken a dump. Under the hood, passenger side on top of the evaporator housing. Easy to check and replace.
Old Jul 8, 2014 | 08:42 AM
Padlock's Avatar
Padlock
That just went over my head lol. How do I check to see if it's bad? Where is the evaporator housing? Where can I purchase one and how expensive.
Old Jul 8, 2014 | 08:54 AM
Padlock's Avatar
Padlock
Would I need a new blower? Or should the resister fix it.
Old Jul 8, 2014 | 09:59 AM
69cj's Avatar
69cj
You need a multimeter to check the different resistors. Your looking for continuity between the pins with a varying degree of resistance. My last post descibed where it is. If you have no idea what I am describing then you need to get some assistance.
Old Jul 8, 2014 | 10:15 AM
Padlock's Avatar
Padlock
When I find it how will I check the pins. I have a multi meter
Old Jul 8, 2014 | 10:30 AM
69cj's Avatar
69cj
Find the common pin and place one probe on it. With the meter on resistance check that pin to each of the others with the other probe. You should read a diff. resistance for each one. High speed will have very little if any resistance. If any of them reads open or no continuity the resistor bank is bad. Hope this helps. It's easier to do than describe.
Old Jul 8, 2014 | 12:03 PM
Padlock's Avatar
Padlock
Well I'm pretty sure that's what it is. Dealership wanted 140 for the part but it's 30 online. I'm just gonna get it and replace it myself
Old Jul 8, 2014 | 01:49 PM
Padlock's Avatar
Padlock
Quick question. Is the resister for the auto temp control the same as the one that has 4 settings??
Old Jul 8, 2014 | 02:22 PM
69cj's Avatar
69cj
That I can't answer.
jez
1983 - 2012 Ranger & B-Series
Jun 19, 2019 11:26 AM
majorgator
Jul 12, 2015 06:41 AM
c_corkill
Sep 9, 2014 11:49 PM
LSUFX4
2004 - 2008 F150
24
Jul 10, 2004 09:48 AM
barbercb
Apr 29, 2001 02:02 PM
