96 4.0 overheat?
Old Jul 4, 2014 | 08:29 PM
fordman626's Avatar
fordman626
96 4.0 overheat?
We've got a 96 ranger 4.0 v6 and we are having a problem with the temperature gauge. Our first guess was the thermostat, but after replacing it twice with new ones the problem continued. We also flushed the radiator the correct way and nothing changed. We narrowed it down to 2 possible points: either the thermostat sending unit is bad or the temp gauge is bad. At a normal idle the truck runs at about H according to the gauge. When you raise the rpm's (we did to 2000 rpm) the temp gauge went 3/4 to H. Its very confusing because when we did the test runs it was running for no more then 5 minutes and never went above 35mph and the engine gave off no heat. Has anyone experienced the same problem or do you know any other reasons for this and how to solve?
Old Jul 4, 2014 | 10:00 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
I would suspect that the fan clutch is not working properly. Can you hear the fan cycle on and off? When the engine is shut down can you easily turn the fan blades by hand?
Old Jul 5, 2014 | 08:44 AM
Hank85713's Avatar
Hank85713
replace the rad cap
Old Jul 5, 2014 | 09:00 AM
KhanTyranitar's Avatar
KhanTyranitar
Gave off no heat, as in the heater doesn't work. This means either the heater core is plugged, or you have lots of air pockets trapped in the cooling system. Air locks will prevent coolant from circulating. Sounds to me like the bypass may not be working other. What brand thermostat did you use?
warren561
Nov 18, 2014 07:52 PM
Keydet13
17
Aug 26, 2011 08:48 PM
shelbymay
Apr 22, 2008 07:11 PM
nick150
28
Dec 20, 2004 02:25 AM
fam
Feb 8, 2004 07:14 PM
