'85 Overheat
Old Aug 21, 2011 | 09:41 PM
Keydet13's Avatar
Keydet13
'85 Overheat
My 85 F150 is overheating. I have new waterpump, radiator, thermostat, cap, and full fluid. No leaks in the system, the fan works ( no fan clutch problems), and there is no debris obstructing air flow. Its a 351W and I know these run hot but its gone out of the normal range just driving 45mph through town roads. Anyone deal with this or have any thoughts?
Old Aug 21, 2011 | 09:56 PM
hemi 27's Avatar
hemi 27
Been overheating since you replaced all of the above stuff?
Fan clutch wore out?
Old Aug 21, 2011 | 09:59 PM
ctubutis's Avatar
ctubutis
In general, overheating while in motion is a radiator or coolant flow problem while overheating at idle is a fan problem.
In general.
What is telling you it's overheating? Have you verified it using a known-good, real gauge with numbers?
Old Aug 21, 2011 | 10:14 PM
Keydet13's Avatar
Keydet13
Haven't verified that my gauge is good, but my temp reading on the dash is good when parked and heater is on. When I turned heater off and backed out (after letting it run for 10+ min w/heater) the gauge went about all the way hot. But I have verified my clutch is good
Old Aug 21, 2011 | 10:20 PM
Gary Lewis's Avatar
Gary Lewis
My 351W runs reasonably cool up to ~45 MPH, but beyond that it overheats in a hurry. Drive around town all day with no problem, but hit the highway and it starts spitting coolant out immediately.
What's the prob? Either a cracked head or a blown head gasket. A leak-down test shows 3 out of 8 cylinders leaking into the cooling system. But, the radiator is fine, the water pump is new, and the thermostat is ok.
The point? If the cooling system seems up to snuff you may have a serious problem. Parts stores sell testers to see if there is exhaust gas in the cooling system. You may need to check it out.
Old Aug 21, 2011 | 10:23 PM
ctubutis's Avatar
ctubutis
Was it ONLY the temp gauge, or did the oil pressure and gas also jump up?
If so, the problem is most likely the ICVR - Instrument Cluster Voltage Regulator.
If it is just the temperature gauge, I would verify what it's telling you as the factory gauges are little more than a general indication of what's going on (when they're working correctly).
You haven't replaced the fan at all, have you?
Did you replace all that stuff in an attempt to fix this problem, or did the problem come about after changing those parts?
Are you sure you have the right water pump? The ones that are for use with the Serpentine belt system have the impeller facing the opposite direction (as it spins the other way).
Old Aug 21, 2011 | 10:34 PM
Anafiel's Avatar
Anafiel
Wow, see I would of just suggested a clogged heater core....
If a heater core is clogged, will there still be good enough flow for cooling?
Old Aug 21, 2011 | 11:32 PM
ctubutis's Avatar
ctubutis
Yes.
Old Aug 22, 2011 | 08:22 AM
ozark1's Avatar
ozark1
I posted the same question about a month ago...on my '84 351W...Two things I learned..ONE..Replaced the sender with generic part from OReillys...BOTH bad...TWO...Fan clutch seemed fine..It wasn't...I replaced the fan..and the radiator with a 3 row unit. Used a FORD sender..Truck runs about on the "N"..and about on the "O-R" in traffic. Just my experience..yours may differ !!
Old Aug 22, 2011 | 09:57 AM
cj06's Avatar
cj06
stock fan ?
Old Aug 22, 2011 | 03:04 PM
ozark1's Avatar
ozark1
CJ06...stock replacement fan for the 351..Also made sure thermostat was 190..My truck had the original radiator...2 row..the 3 row made all the difference.The radiator was $160 at OReillys. I researched several radiators..Quality was OEM or better...Fit was as original, even though it was a bit thicker... no shipping costs..and local ..in case of a problem...
Old Aug 22, 2011 | 03:35 PM
Archion's Avatar
Archion
Veteran: Marine Corps
What part # did you get from O'Reillys?
Old Aug 22, 2011 | 04:56 PM
Gary Lewis's Avatar
Gary Lewis
This isn't Ozark1, but we've talked about his radiator. I believe the O'Reilly # is 433561 and is for a 351. It costs $189.94, is made by Murray in the US, and is a 3-row copper/brass radiator.
Having said that, I believe I'm going with the radiator O'Reillys carries for an '85 460, which is #432183. It is $145.99, is a 2-row aluminum, and is made by Murray in the US.
Everyone I've talked to, including the man at Murray which the O'Reilly man called, says that a 2-row aluminum will cool the equivalent of at least a 3-row copper/brass and closer to a 4-row. And, I've found statements to that effect on-line as well.
Old Aug 22, 2011 | 05:37 PM
ozark1's Avatar
ozark1
Part # is ..433561..Price is higher than when I bought mine 3-4 weeks ago. I, too, looked at the aluminum 2 and 3 row that are available....Murray and others..I called an old friend in Florida that built the radiators when we were building replica Cobras and GT 40s, and asked what he would do for my specific situation. He said...and bear in mind, everyone has an opinion,...that the aluminum are no better cooling than C/B. He advised to go with the 3 row. I did not use price in my decision. Having said that...I have driven mine in town, on the road, and stuck in construction traffic here at home. Has never passed "R" on my factory gauge ..and I have a new S-W mechanical temp. gauge that I'm going to install when I get in the mood. I'm pleased with my choice..As I said the quailty was equivalent, and the fit as original..Works for me.....JV
Old Aug 22, 2011 | 05:50 PM
cj06's Avatar
cj06
my opinion is that the bigger the better = more water
