Welder question
Old Jul 3, 2014 | 01:41 PM
  #31
rews2's Avatar
rews2
Originally Posted by HIO Silver
A 120v welder is only good up to 3/16ths because there is simply not enough current (amps) to push the heat deep into the work piece. 20 amps is a typical household circuit... I have a 50-amp circuit (30a is minimum) because I now I can use 100 feet of 8/3 extension cord without suffering a significant voltage drop at the end... I can weld on the other side of my house or across the street if I need to.
Miller 211... do it!!
On the amps. I have a 20-amp circuit, so far with my practice welds it seems fine. Should I step it up to 30amp or for my use will 20amp work fine?
I wouls like the option of moving the unit closer to the center of my garage which would mean extension cord. Suggestion on gauge and length I can use to not drop amperage?
Old Jul 3, 2014 | 01:48 PM
  #32
Randle's Avatar
Randle
Use 12 gauge cords smaller cords could start tripping breakers and it want weld as good, 20 amp breaker is fine just watch other things running on the same circuit.
Old Jul 3, 2014 | 01:59 PM
  #33
rews2's Avatar
rews2
It's a dedicated 20amp just to the outlet I have been using. the outlet is a single plug which my plan was to pull the single plug and change out to a double with the built in trip breaker
Old Jul 3, 2014 | 02:07 PM
  #34
HIO Silver's Avatar
HIO Silver
A 20-amp breaker using 12/3 cabling is fine. IIRC, the recommended maximum length extension cord on a 12/3 for a 110v welder is 25 feet rated for the same.
jrockdiddy
Nov 21, 2014 02:43 PM
Richardl12
22
Dec 15, 2009 03:34 AM
19fifty4
15
Oct 2, 2008 02:07 PM
airride41
Paint & Bodywork
Nov 23, 2007 06:11 AM
mfraley65
Paint & Bodywork
19
Dec 28, 2006 08:37 PM
