Transmission filter question
Old Aug 5, 2006 | 05:28 PM
hink10's Avatar
hink10
I am getting ready to change fluid and install an external transmission filter. The fluid has about 35k on it, but I changed the filter about 20k ago when I installed a Sonnax kit. Can I get away with leaving the filter in the trans and just doing a flush? The external filter will be doing most of the filtering and I have heard the internal filter can last 100k. I'm just trying to avoid the mess of dropping the transmission pan. Is it necessary, or can I wait until next change? Thanks.
Steve
Old Aug 6, 2006 | 04:28 AM
7.3powerstroke's Avatar
7.3powerstroke
How dose your trans fluid look? As long as it isnt burned or discolored you might be ok to change the internal filter ever other fluid change. Also what type of trans fluid are you running in it?
Old Aug 6, 2006 | 05:55 AM
Cuda_jim's Avatar
Cuda_jim
The external filter is a good idea but you could add a drain plug to the pan to avoid the mess too.
Old Aug 6, 2006 | 06:15 AM
JOE-M's Avatar
JOE-M
The internal filter can be left alone, you don't need to change it. Just flush your transmission and add your external filter and you'll be fine. The internal filter can go 90k with no problem.
Joe
Old Aug 6, 2006 | 07:39 AM
Chance_Thomas's Avatar
Chance_Thomas
Where is the external trans filter? I will be doing the BTS VB in the next couple of days and will be replacing the internal filter.
Old Aug 6, 2006 | 08:57 AM
Cuda_jim's Avatar
Cuda_jim
That's an add-on. Stock trucks don't come with one.
Old Aug 6, 2006 | 08:59 AM
Cuda_jim's Avatar
Cuda_jim
Joe
I would not recommend 90k on the filter. 30k is more like it, less is even better. It's cheap insurance for the weak links in the drive line.
Old Aug 6, 2006 | 11:58 PM
hink10's Avatar
hink10
Thanks for all the input guys. I installed the remote filter today (thanks Jeremy), didn't get to the fluid change though. I have been reading a bunch and it looks like a lot of folks are recommending filter changes every other fluid change. I may just leave the internal filter until next time. It has been changed since the last fluid change and I've had a Magafine inline filter installed for a good bit of the time. I have a drain valve on the remote filter, so flushing the trans will be easy. I didn't have the hose clamped tight enough on the return line when I flushed it the last time, made a real mess! Thanks again for the input!
Zip
Jun 16, 2014 10:57 PM
KIDkiser
Apr 11, 2014 08:50 AM
bismic
Jul 31, 2013 11:40 PM
Schmitty133
Nov 11, 2010 07:30 AM
builttoughf350
Aug 7, 2010 10:37 PM
