Transmission Filter Identification / Replacement
I've attached a picture (left is the front of the truck, right is the rear of the truck):
I would appreciate if someone confirms that this is a transmission filter. If yes, I would also appreciate if someone can tell me if this is a filter that can/should be replaced by the Magnafine transmission filters. I've also emailed Magnafine.
I realize I have an option to switch over to a more robust transmission filtering system (e.g., using Baldwin filters), but I'm not sure I use my truck enough to warrant the expense.
Thanks in advance for your help.
You'll want the 3/8" Magnefine.
Any idea how much fluid I'll lose when I change filters (assuming I'm reasonably quick in changing the filter). Is the fluid under pressure when the truck is not running?
Magnafine makes them for Ford, and they are good for what they do.
I believe that a spin-on (with magnets) does a better job, with better flow characteristics.
Pop
You were spot on with the amount of fluid loss. Do I need to replace the cup of fluid lost or is it insignificant if the transmission dipstick shows me in range?
I've linked some pictures of the inside of the old Magnefine filter:
http://i1058.photobucket.com/albums/...psoqrciclp.jpg
http://i1058.photobucket.com/albums/...psrmp63lyr.jpg
http://i1058.photobucket.com/albums/...psff8yf1sq.jpg
http://i1058.photobucket.com/albums/...pssksf3gtk.jpg
Not too much to see here. I'm not sure when the PO replaced the filter but the transmission was replaced with a re-manufactured transmission in 2009.
That filter looks like it's been doing its job collecting "crud"!
Replace with another and change at a shorter interval!
Pop
IMO: Any filter is better than none! But, if you have a chance one day, I would check the flow before the filter and after the cooler just to ensure the cooler is flowing to spec. I can't see ford producing a newer SB and requirement for a new cooler for no reason. They seem to be on top of things like that.
I did see a joke the other day: What's faster than a 350 Ford Cobra? GM Recalls lately
It is usually on the inlet side of the filter, and I didn't see a magnet, but since that filter is is not a true "Magnefine" filter (I suspect it is an SPX Filtran), I was wondering what they looked like inside. It also occurred to me that you might have opened the filter up on the outlet side, and the magnet might still deep inside your cut open cylinder, on the inlet side.
Which side did you open up, the outlet side or the inlet side? Do you mind taking the rest of it apart to see if that filter unit had any magnet at all?
I'll revisit in the morning to be sure I didn't miss something.
I had the sense that the magnet was bottom center of the third picture, but I'll confirm in the morning that what I thought is a magnet is in fact a magnet.
In making my original comment that there didn't appear to be anything worth noting when I opened up the filter, I was really focused on the absence of metal particulate in the filter. Then again, my guess (and I think this was whitetmw's point) is that debris is being trapped in the cooler.
But the filter in THIS thread is none of these. Ford moved away from Magnefine filters, going with a different supplier, but keeping the same basic part number (7B155), only changing the prefix and suffix to those part numbers.
Notice that the filter body in David's first post is smooth? That is not a Magnefine supplied filter. I suspect the filter supplier in this case is Filtran. The internal parts to this filter are different as well. For example, the bypass spring is much shorter on this filter, about half the length, as observed from the photos the OP later posted.
Ford issued a special service message articulating engineering's concern about inline filters leaking and not going into bypass mode... so it would not be unreasonable for Ford to have moved to a non-openable inline filter, before dropping them altogether.
Ive never personally seen the type of filter David has in real life, but it seems possible that in this case, this filter may not be as easily openable as the Magnefine.
The only question is... like a ship in the bottle, how did the filter media get into the pod WITHOUT it being openable? David's picture in his first post does show a groove on the left hand side of the filter housing. Could that be where it opens?
http://i1058.photobucket.com/albums/...ps0xqkayy5.jpg
http://i1058.photobucket.com/albums/...psqmnlhwqb.jpg
http://i1058.photobucket.com/albums/...pslux6sxqm.jpg
http://i1058.photobucket.com/albums/...psvjtvzb2k.jpg
http://i1058.photobucket.com/albums/...psrx5jeyug.jpg
Some thoughts. There's a round rubber piece that I hadn't previously noticed that had fallen on the floor in the lower right of the first picture. I can't swear that it's even from this assembly but I suspect it is. In the various pictures, I tried to keep the parts in the order that I believe they should be assembled. What I thought was a magnet (shown copper color in picture 4) is not. However, there is a magnet and it is the sleeve inserted in the cylinder (and upon removal proved to have quite a bit of sludge - but no parts - attached to it). Though I doubt it would move as assembled, it freely rotated when I went to disassemble it. The last picture attempts to show how the inner parts are assembled. If you would like me to drop the assembly in a Ziploc and box it and mail it to you, I can do so.
I've got a stock cooler.
I know what has been reported as ideal for these transmissions, but I'll keep an eye on the temperature gauge in case there is an obstruction (which I don't think I can know other than by watching the transmission fluid temperature).
I didn't think I would get up to 175F that fast.
In the event there is a blockage, is there some type of bypass? If not, am I correct in assuming the fluid will simply blow out at the weakest point?
Thanks.
