Broke 22 mpg
Old Jun 28, 2014 | 02:42 AM
cjgray1974's Avatar
cjgray1974
Broke 22 mpg
I went down to the Ozarks this week to help my sister in law and her husband move back. got 17.67mpg on the way down and 22.76 on the way back, running the air and trying to keep it under 2000 rpm.
What really helped on the way home was following my brother-in-law in the U-haul all the way back. He would get going about 75 downhill and be down to 60 at the top of the next. So I pretty much coasted halfway up most of the hills.
Yes that's hand figured, not off the Lie-O-Meter. Just had to get on here and brag.
Old Jun 28, 2014 | 05:06 AM
Tugly's Avatar
Tugly
Indifferent to those who cringe at the P word - my Prius demonstrates one other factor in this that helped with the economy - drafting a U-Haul. The "overhead" on the Prius is very detailed and sensitive, so I can immediately see how different conditions effect economy. You don't have to tailgate to get a good draft-bump in economy. Every time the headwinds hit, I'm hidin' 'hind a heavy hauler.
I've had as high as 19.6 on uninterrupted highway drives while keeping speed uphill and not drafting - your numbers are perfectly viable.
Old Jun 28, 2014 | 10:20 AM
GHeTTo JOe's Avatar
GHeTTo JOe
what did the dash say for fuel mileage
Old Jun 28, 2014 | 01:44 PM
cjgray1974's Avatar
cjgray1974
I have my overhead pulled out right now, needs some re-soldering done and I need to find where to get the chips in it as one is missing.
Old Jun 28, 2014 | 10:17 PM
Tugly's Avatar
Tugly
I think Radio Shack has SMD (Surface Mount Device) resistors - that's what the "chips" are. I'm going off memory, but I think they read "610" or "620". In electronics jargon, that's 61 ohms and 62 ohms - not 610 ohms and 620 ohms, as one might assume.
Old Jun 29, 2014 | 04:23 AM
cjgray1974's Avatar
cjgray1974
Thanks Rich, I'll have to check that out. You wouldn't happen to know where I can find out which one goes where would you. There is one missing and I'm not sure what size it is. I haven't looked at it for a few weeks, but I think there are 3 different sizes in there.
Old Jun 29, 2014 | 08:08 AM
Tugly's Avatar
Tugly
There are two different sizes. There are three of one size and one of the other - and I "guessed" at which went where, with success. Looking at the orientation of the resistors and the traces on the board, this looks like a couple of voltage dividers. Given the closeness of the values of the resistors, I would hazard an educated guess that their position won't make enough difference to matter.
If somebody has a picture of a board that works, this would be the best answer.
superhooperduty
Mar 10, 2014 11:36 AM
jake2582
17
Oct 29, 2010 03:42 PM
Mallie
6.4L Power Stroke Diesel
59
Sep 12, 2008 10:06 PM
eric777
May 29, 2007 04:21 PM
s2gots
Oct 2, 2004 03:24 PM
