When did the climate controls change?
Old Jun 28, 2014 | 10:40 AM
9905's Avatar
9905
I am not a fan of the digital. In the winter, I don't like the fan blowing full blast when there is no hot water in the heater core. Has anyone gone from digital to manual and if so what kind of problems is there? Not a big deal but if its an easy swap I would do it. If it's remotely a PITA, I would not think twice about leaving it.
Thanks.
Old Jun 28, 2014 | 11:30 AM
Misky6.0's Avatar
Misky6.0
Thanks.
You realize you CAN still manually change the fan speed? On mine, in heat mode until engine coolant reaches 100* the fan stays on low.. then speeds up.
Sent from my Sprint PC36100 using IB AutoGroup
Old Jun 28, 2014 | 12:23 PM
1 Excursion camper's Avatar
1 Excursion camper
In auto does it not "delay" the fan untill the engine warms up! I know almost all other manuf do this.
Old Jun 28, 2014 | 01:25 PM
Misky6.0's Avatar
Misky6.0
On mine, when coolant hits 100* the fan goes to high, when it's cold here in Fl, those 3 or 4 days a year. :-)
Old Jun 28, 2014 | 02:02 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I dont think i've ever used the "auto" setting.
Typically i either have it set on 90f and fan on high, or on 60f and max a/c w/ the fan on high.
i'm just hot'n cold haha
Old Jul 1, 2014 | 09:04 PM
Pele's Avatar
Pele
How does the climate control know the coolant temp? Is there communication to the PCM or is there a separate sensor?
If someone were to do an engine swap...
Maybe ECT data is on a standard OBD2 PID...
Old Jul 1, 2014 | 09:42 PM
Apocalypse's Avatar
Apocalypse
I have an 02 limited and the crappy ***** I would kill for the digital!
Old Jul 2, 2014 | 12:25 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
If yours is truly a 2002 it should have the digital controls. check your door tag for the build date in the upper left corner of the tag...i'm curious.
Old Jul 2, 2014 | 09:00 AM
Snowseeker's Avatar
Snowseeker
I like my digi controls. I almost never use the auto feature though, I just set the temp I want and then set the fan at like 3 bars.
Old Jul 4, 2014 | 08:28 AM
Studawg's Avatar
Studawg
Thread Ender
I searched for a year for a low mileage rust free 4x4 7.3X Limited. Insisted on limited for the digital HVAC controls and the ability to control them from the steering wheel. Love that feature.
Old Jul 4, 2014 | 08:40 AM
Apocalypse's Avatar
Apocalypse
I'll post a pic up today I'm not 100% either so it would be nice for me to know as well
Old Jul 4, 2014 | 09:21 AM
Misky6.0's Avatar
Misky6.0
On a long drive the front air dries our eyes, i turn the rear a/c on medium fan speed and leave front on auto and front speed stays low.
Old Jul 5, 2014 | 02:20 PM
  #28
sessland's Avatar
sessland
Nice tip!
I'll have to give this a try
Old Jul 5, 2014 | 02:38 PM
  #29
Apocalypse's Avatar
Apocalypse
My stickers are gone However the wife says it's an 01 so that might be my issue I'll post my vin later on tonight.
Old Jul 6, 2014 | 01:32 AM
  #30
Vr4tune's Avatar
Vr4tune
Look at the 10th diget of the vin if it's a 1 then it's a 2001 if it's a 2 then it's a 2002.
1999-F150
Escape & Escape Hybrid
Mar 21, 2019 01:26 PM
billb
Apr 11, 2017 01:55 PM
Dogmann
Feb 7, 2014 09:29 PM
andrew240z
Apr 16, 2005 12:15 PM
counteyd
Car/truck Buying Advice
Mar 26, 2005 11:35 AM
