roof rust
Old Jun 24, 2014 | 10:06 PM
newguy399's Avatar
newguy399
roof rust
so i took the tarp off and look at the cab and found this on the passenger side,
how bad is this to repair, any advice on how to fix it. in my gallery its the last two pictures. its under the drip rail, thanks in advanced
dan
Old Jun 25, 2014 | 08:49 AM
AXracer's Avatar
AXracer
can't find your gallery or pictures.
Old Jun 25, 2014 | 08:52 AM
fabmandelux's Avatar
fabmandelux
They are here: https://www.ford-trucks.com/g/album/921754
Old Jun 25, 2014 | 09:07 AM
AXracer's Avatar
AXracer
Unfortunately that is a big job It's a complex joint and only the inner doubler panel is available as a repair panel. That much rust that high up means that it likely has severe rust around the windshield and lower. If you are not well versed in rust repair and patch panel fabrication, I'd suggest looking for a better cab. All cabs from the F100 through the big jobs are the same and useable. Even if you shop the SW states for a rust free cab, and have to have it shipped, or fly to the location and rent a truck one way to bring it home, it will be cheaper than repairing what you have, especially if you have to hire out the work.
Old Jun 25, 2014 | 09:24 AM
blue_cloud's Avatar
blue_cloud
see this thread https://www.ford-trucks.com/forums/1...st-repair.html
good photos and you can see what you may be getting into.
I have a 56 cab that is much worse than yours, I'm going to repair it, in the meantime I do have a spare cab in better shape.
Jeff
Old Jun 25, 2014 | 09:41 AM
newguy399's Avatar
newguy399
Thanks guys, I have looked around the cab that is the only really bad spot on the whole roofline some minor holes to fill,is there any to make a patch panel for that spot
Old Jun 25, 2014 | 10:42 AM
CharlieLed's Avatar
CharlieLed
If you looked at the thread that blue cloud posted then you will realize that what you are seeing on the outside of the roof panel is just the tip of the iceberg. When you remove the damaged metal skin you will surely find more rust in the supporting substructure.
Old Jun 25, 2014 | 11:10 AM
newguy399's Avatar
newguy399
Yeah you guys are probably right,that's a bummer.....
Old Jun 25, 2014 | 11:25 AM
AXracer's Avatar
AXracer
The water and corrosion that rusted that area came from the inside and first rusted the inner structure and likely also attacked the underside of the "forehead" over the windshield and down the posts to the area under the windshield weather stripping. A pinhole showing on the outside means the metal had been thinned on the inside for at least 6" around it, too thin to weld to. The door frame under the gutter is a box structure composed of several separate pieces welded together. In my experience a 3-4" strip of the roof most of the way around and the inside layers and gutter will need replacing along with almost all the box section over the door. The best way to do the door frame section would be to cut it out from front to rear door posts and replace it with a matching section from a cab without rust. I find it unlikely that there isn't rust in the lower cab corners and door posts, there had to be a lot of moisture, and unless the cab was upside down it would have run down to the bottom.
Old Jun 25, 2014 | 12:06 PM
newguy399's Avatar
newguy399
Yeah ax your right the lower cab corners need to be replaced,just out of curiosity what would a used cab cost
Old Jun 25, 2014 | 12:22 PM
AXracer's Avatar
AXracer
56s tend to be a little more than 53-55, but I have seen SW rust free bare cabs selling for 400. (without doors) - 800. (with doors), shipping ~ 500 or less depends where you live, if you pick it up at the truck terminal, etc. Search craigslist in major areas in SW. Mid Fifty sometimes has used parts for sale. The cabs on big jobs are often in better shape and cheaper, they are identical.
Old Jun 25, 2014 | 05:55 PM
ben73058's Avatar
ben73058
Hey Dan,
Here are (2) more threads with different approaches to roof and drip rail repair. The first is the traditional approach of cutting out the rust & welding & doing repairs. The second is from Capelo in Spain - where he totally replaced his roof with a fiberglass one. (around page 9 on his thread).
https://www.ford-trucks.com/forums/1...t-welds-2.html
https://www.ford-trucks.com/forums/1...rd-f100-9.html
I wouldn't be discouraged - most of us started with trucks that were err.. basket cases or barn finds. There is no harm in opening up the roof a bit & taking a look.
Good luck over there & welcome!
Ben in Austin
1950 F1
Old Jun 26, 2014 | 09:55 AM
newguy399's Avatar
newguy399
Thanks for the replys that's why these trucks are fun,will figure it out
Microchudd
Jun 11, 2011 02:26 PM
shoveex
Mar 9, 2010 11:45 PM
Rambo76
Jan 3, 2009 05:20 PM
69Charger
Paint & Bodywork
Aug 21, 2003 06:04 PM
