rust how to?
Old Mar 6, 2010 | 10:29 PM
shoveex's Avatar
shoveex
rust how to?
the only bad rust on the vehicle is the roof rain rail about the windshield, its completely rusted through in spots. how would i go about fixing that?
Old Mar 6, 2010 | 10:33 PM
52 Merc's Avatar
52 Merc
Just like any rust, you have to cut out the bad parts and weld new metal back in. It's a little more of a pita when you're dealing with multiple layers and drip rails, but the method is all the same.
Old Mar 7, 2010 | 11:32 AM
Randy Jack's Avatar
Randy Jack
What Wayne said.
Old Mar 7, 2010 | 12:28 PM
CharlieLed's Avatar
CharlieLed
The only thing that I would add to what Wayne posted is that you should gain an understanding of the design of the panel that you are repairing BEFORE you start the job. For instance, on a 56 cab the roof panel flange at the drip rail is the top part of a three layer pinch weld. The bottom layer is the upper section of the door jamb and sandwiched in the middle is the actual drip rail. These areas are prone to rust because the original seam sealer used in 1956 shrunk over the years and allowed moisture to seep into the seam. If you have rust-out in one area then the chances are that this is just the tip of the iceberg...the rust will creep along this seam even though you may not be able to see it now. Remove all old seam sealer and inspect the drip rail seam both from the outside and the inside of the cab. Remove and replace all rusted metal and use a quality seam sealer all along the drip rail. It's a PITA both worth the peace of mind knowing that you won't have to ever do it again.
Old Mar 7, 2010 | 07:41 PM
mt54's Avatar
mt54
Originally Posted by Randy Jack
What Wayne said.
Not to hijack the thread... But
Randy, good to see ya back, haven't heard from ya in while. I hope all is well with you.
Old Mar 7, 2010 | 09:40 PM
MP&C's Avatar
MP&C
Here is a thread I did on drip rail repair. Excuse the brand, the process should be similar....
Roof and drip rail repairs - Welcome to TriFive.com Classic 1955 - 1956 - 1957 Chevy's Forum, Photo Gallery and Classifieds. Here you can Buy, Sell, or Trade. Get or Give Advice, or Just Talk Classic Cars.
Old Mar 7, 2010 | 10:08 PM
shoveex's Avatar
shoveex
awesome link! this is kind of what i was looking for.. the only problem i see is the rust out is on a bend but ill figure it out.
Old Mar 9, 2010 | 11:45 PM
brucewolff's Avatar
brucewolff
Super info in that link!
Farmboypowerstroke
Jan 25, 2013 04:58 PM
bbsitum
1997 - 2003 F150
Jun 10, 2009 06:21 PM
TxFordGuy
May 26, 2009 11:36 AM
forddytube
Paint & Bodywork
Jan 19, 2004 12:43 AM
fordtruckin
Mar 25, 2002 11:21 PM
