Fuel leak advice
Old Jun 24, 2014 | 09:06 PM
Fordownsall's Avatar
Fordownsall
Fuel leak advice
96 f350 7.3L 4x4
Hey guys I got a fuel leak from what appears to be behind the alternator bracket area. Just replaced the drain valve a couple days ago, have rebuilt the fuel bowl about a year ago, several new fuel lines, and a new sensor, all were leaking fuel. This leak seems to be coming from behind the alternator and bracketry coming from the front of passenger side head. I know fuel is fed into the back of the heads, is there a fuel line that comes out of the front of the head too? What is there that contains fuel? any advice thank you.
Old Jun 24, 2014 | 09:18 PM
fordman67's Avatar
fordman67
Yep.the fuel returns out front of head behind alt and goes to the regulator.the hose has ruptured most likely.
Old Jun 24, 2014 | 09:20 PM
ReBilld's Avatar
ReBilld
X2^^^^^^^^^
Old Jun 24, 2014 | 09:38 PM
Fordownsall
thank you. so it's a hardline. i wonder if pulling the fuel bowl is necessary to change it?
Old Jun 24, 2014 | 09:52 PM
fordman67's Avatar
fordman67
Looks about a hydraulic line. No fuel bowl removal needed
Old Jun 24, 2014 | 09:58 PM
Fordownsall
great, thanks fordman. =D
Old Jun 24, 2014 | 10:23 PM
Robbieo11's Avatar
Robbieo11
I just did mine here is what i did i cut the old hydralic crimp off pulled the barb and fitting. Bought high pressure fuel line and used hose clamps to secure.
This will give u an idea of what i did
http://www.thedieselstop.com/forums/...es-off-fpr.jpg
Old Jun 24, 2014 | 10:43 PM
Fordownsall
thanks robbie to verify the line, mine is leaking from the other end though
Old Jun 24, 2014 | 10:49 PM
Robbieo11's Avatar
Robbieo11
imagejpg1.jpg Photo by robbieo11 | Photobucket
Mine where dry rotted and split most likey yours are close behind see if the fittings are loose
Old Jun 26, 2014 | 10:08 PM
Fordownsall
thought I would update this post for anyone in the future,
The line that I thought was leaking I had actually already replaced a few months ago(it was leaking too). It is easily accessible without removing anything.
my fuel rail gallery plug was leaking. it was about 14 bucks (list price) from Ford dealership. There's also an oil plug behind that bracket. The oil plug is 1/2" drive and the fuel plug is 1/4" drive. Remove serpentine belt, remove alternator, remove 3 or 4 bolts holding the bracket on. the fuel plug is lower on the head closer to the exhaust, the oil plug is the large 1/2" drive plug.
dealership actually sold me the oil plug first telling me that it was the fuel plug, so I had to come back and get the fuel plug, the oil plug is about 8 bucks, thats at a list price.
f350xlt460
Feb 19, 2023 08:41 AM
mudrat025
Jun 27, 2013 08:06 PM
Andy's Beast
Feb 25, 2013 07:17 PM
tdorval
Feb 2, 2009 07:19 PM
meccox
Jun 12, 2007 08:42 AM
